Author Topic: Things I've learned about my K bike.  (Read 5041 times)
Offline Novafrk
« on: October 22, 2014, 06:36:30 PM »
Today I learned that the 5 "captured" nuts that the muffler heat shield is attached to aren't in fact captured at all.
I also learned that you will lose all five of them riding around the block without the heat shield attached.  :riding:
88 K75S - My red headed mistress. Shhhh.
Re: Things I've learned about my K bike.
« Reply #1 on: October 25, 2014, 08:31:52 PM »
I'm missing one myself. Anyone know where to get them aside from the dealer?
If you have to order them, get an extra one for me, I'll send you a SASE and a dollar.
Btw you can get the screws for your local Fastenal but not as short as need, so you'll have to grind or cut them down.
Offline Novafrk
« Reply #2 on: October 26, 2014, 07:33:47 AM »
I was unable to find anything that had the same dimensions as the factory nut. I just ordered mine from Max BMW... The shipping was more than the nuts. I was irritated about that but feel the heat shield was probably put there for a reason. (melting bags?) I did get replacement screws from Fastenal in ss. I am thinking of just putting a washer between the heat shield and the muffler plus one under the head to take up the 2 mm extra length. I cut bolts down all the time but only being 8mm long there's not much room to work with.
Offline ReneZ
« Reply #3 on: November 16, 2014, 08:06:29 AM »
There should be washers any way. Have a look at the fiche.
Greetings, Rene
BMW K100 - 1984
BMW K1200GT - 2003
Offline Novafrk
« Reply #4 on: November 19, 2014, 10:28:36 AM »
I sure thought there should have been washers under the bolt but they were missing from mine. I didn't bother to look for one when I looked at the fiche because I knew I was going to put one there regardless.  :dunno2: PO must have dropped them all.
