Author Topic: Plastic end caps on the engine guards  (Read 5788 times)
Offline Billk
« on: October 20, 2014, 01:36:58 AM »
Does anyone know how to remove the plastic caps used on the engine guards without destroying them? That would be number10 in the diagram.
I have a 1995 K75
Do does the engine guard have to be removed to adjust the valves. In other words is the valve cover in the way?
Bill
  • NYS
  • Owned many BMWs and Harley's presently '95 75K and '14 V Strom
Presently own a 1995 K75 and a 2014 Suzuki DL650
Re: Plastic end caps on the engine guards
« Reply #1 on: October 20, 2014, 06:55:10 AM »
I've just put a workshop towel around the edges and carefully grabbed it with a pair of pliers and pulled it out.
As far as requiring to have it off? can't specifically say about a 75.
I know that on my 1100's it has to come off to get my side panel off.
Offline Zipster
« Reply #2 on: October 20, 2014, 06:27:49 PM »
I couldn't figure mine out a few months back but I found that the caps moved slightly so I did the towel and pliers trick and was able to turn then 90 degrees. Then it was just a wobble to and fro to get them out.
  • Northern Ireland
  • 1996 K1100 LT SE - sold with 104,500 miles in 2015; 2001 R1150RT - 68,000 miles; 2013 Triumph Trophy SE - 50,000 miles; 2007 Harley Ultra Classic - 50,000 miles (Canada bike for stateside use only)
Add life to your days, not days to your life!
« Reply #3 on: October 20, 2014, 08:45:21 PM »
As mentioned, you just pry them out.  they are only held by friction.
I can also speak to the question re removal to get the valves cover off:  No you do not need to remove them.  If you have a RT model the left lower will need to come off and the guard runs through the lowers so that is a bit awkward but not insurmountable.  Just let the lower hang from the guard.
HTH
