I had a bit of an uncharacteristic (for me) strop and got rid of this post. Then I thought, nah, I stand by everything I wrote so it's back........
Now,
tenders/chargers.I dislike tenders and in fact all 'smart' chargers quite a very lot. I'll just get that out of the way. I have tried a few for the sake of experimentation and all of them are no longer with me.
The only 'tender' I would ever recommend is
using the vehicle. If your charging system isn't good enough to keep the battery charged or the battery will not hold a charge for more than a few days, then fix it/replace it. Don't fanny around masking the symptoms of failing parts with a 'tender'.
The 'recovery' function is very hit and miss, I have recovered batteries that an optimate said were beyond it, and I have had a battery that an optimate said was good be very bad indeed. I will only share my recovery methods if directly asked - it's fairly dangerous and I would never tell anyone to try it.
An alternator is the best battery charger you can get. Jump start the bike and take it for a ride. It will not stress the alternator, the battery or your dog/cat/hamster - the alternator is designed to provide it's rated output all day long and will do it happily.
The second best battery chargers are 'linear' - just a transformer and rectifier. Charge current is regulated by the design of the transformer core.
One final point - NEVER charge a battery while it is installed in the vehicle, or for that matter indoors. If a battery is being charged
properly it will emit hydrogen gas, which is ever so slightly volatile. If it's not emitting gas, it's not being charged properly if at all.
Jump starting.Following the very enthusiastic failure of my alternator drive a while ago, on the offchance I ever need to jump start my K, I did this:
I put a random angle bracket on the positive terminal...
As everyone knows, you should never connect both cables directly to the battery on the 'slave' vehicle when jump starting, with this little bracket it means I can pop the side cover off, connect standard car jumper cables to the battery positive and one of the engine mount bolts, and away we go.
I have recently heard a few people say never to jump start a bike from a car, and if you really have to then to never have the car running - my one-word response:
Crap.
"Oh but the electronics!"
More crap.
Why do you think the alternator output from a car is different than the alternator output from a bike? Especially on a K, which uses a car alternator anyway... It also use a car injection ECU, and a car ignition ECU... A higher capacity alternator will not 'push' more power into the system, it will simply provide what is demanded - that is how electricity works. Same with using a loose donor battery, the only time size is relevant in any way at all is if it's too small, then it just might not work.
Sorry to say this, but if you have had anything fail or break 'due to jump starting' then you have done something wrong.
The right way:
1. If you are using a car as the 'donor', start it. If you are using a loose battery, put it somewhere convenient.
2. Connect the red/+ve jump lead to the donor battery +ve terminal, THEN to the slave +ve terminal.
3. Connect the black/-ve jump lead to the donor battery -ve terminal, THEN to a good earth point on the slave, NOT to the battery terminal.
4. Start the slave vehicle.
5. Remove jumper cables in this order: slave -ve, donor -ve, slave +ve, donor +ve.
6. Only then, turn off the donor engine.
DO NOT attempt to start the donor vehicle after connecting the slave. When jumping FROM a vehicle, always have it running. Also, be careful waving those jump leads around so you don't short anything.
