Author Topic: trans neutrals when turning left in2nd gear  (Read 5570 times)
Offline racinrich
« on: August 17, 2014, 09:12:45 PM »
anyone heard of this one ? I'm turning left not accelerating hard and it neutrals if I hit a slight bump . I am leaning pretty steep.
1993 k1100 lt silk blue
des plaines ill
USA
Re: trans neutrals when turning left in2nd gear
« Reply #1 on: August 17, 2014, 09:59:23 PM »
Slow down and lean less.
« Reply #2 on: August 17, 2014, 10:28:32 PM »
try right turns...
« Reply #3 on: August 17, 2014, 11:41:33 PM »
try right turns...
I was thinking don't ride on the nascar tracks........ :hehehe
But seriously, you aren't touching the shift lever on accident with your boot?
Offline racinrich
« Reply #4 on: August 19, 2014, 12:08:15 PM »
REALLY ? ??
des plaines ill
USA
« Reply #5 on: August 19, 2014, 01:04:22 PM »
I read a post here recently about someone who thought they found the neutral detente ball in the drain pan after changing gear oil. I'm not sure what that ball does but if it does what it sounds like it does, then it might have something to do with it.
Maybe you could put it on the sidestand and try to recreate it.
Offline subforry
« Reply #6 on: August 19, 2014, 02:59:57 PM »
Sounds like an interesting problem.  I really doubt that the shift lever is hitting the ground.  If you placed a stick with one end between the tires and angled it up until it hit the lever, I think the stick would be more upright.  Of course you have to account for the suspension being loaded up.
Also there would be scratch marks on the lever.
Has the bike been dropped on its left side?  Seems like M/C shift internals can be damaged when the bike is dropped on the shift lever.  Is the trans oil level correct?
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline racinrich
« Reply #7 on: August 19, 2014, 10:11:35 PM »
bought donar bike in pieces,it was totaled from a fall over but on rt side . left panels were all ok shifter is unmarked , level is perfect no leaks, boot almost never touches ground and boot is not touching shifter, when it happens I pull up on shifter and its in 3rd , I do not feel any other issues , this trans 45k original was 110k ,definitely shifts better than original
des plaines ill
USA
