PDG: good points...
The colour isn't really the bike's fault ;)
but if it were red I would have tried a lot harder to ignore the problems
The transmission is essentially the same as on the K, if it's more clunky and backlashy then it's worn or broken...
probably so, the salesman was very surprised when I mentioned clunks
Less nimble? Well, it is bigger.
yep
Vibration is going to happen, in fact the K is unusual with it's lack of vibration...
true enough
The 1150 should pick up quite quickly - see drivetrain.
Yes, I think this one was probably "run hard and put away wet" which is why the price is so low
Overall, it's a different machine. A good one can be good, but even then it's maybe bad for you. I still want an airhead boxer, but not a standard one...
With all the R bike aficionados I have to assume that this R was not representative of most. The test drive yesterday was the first time I ever rode one. Will look forward to another chance to try another
