Author Topic: New question - how much does a final drive unit weigh?  (Read 4070 times)
Offline Mongrel
« on: August 06, 2014, 12:55:54 AM »
I just want to confirm something. Assuming that you have an '86 or newer bike as I do (i.e. the output drive shaft is 20 splines) how swappable are final drive units (not the drive shaft) between different models of K75s and K100s? For instance, I could get a K100 final drive unit and put it on my K75?
I believe they're fully interchangeable, but couldn't find that for sure and just wanted to confirm that. Or would that not work? Sometimes I see part listings that mention the pinion gear ratio and I'm just wondering if that's being done for completeness' sake or if there are actually variable ratios.
'86 K75c
Offline pdg
Re: Swappability of final drive units?
« Reply #1 on: August 06, 2014, 05:42:20 AM »
There are a few different final drive ratios, usually the FD has it stamped on or near the flange to the arm. Which one you end up with makes a little bit of difference to the acceleration/top speed ratio.
I have a K100 FD on my 75 at the moment... According to the PO, that was a cheaper option than getting the bearings replaced in the original unit.
1988 K75S
Offline frodef
  • 1986 K75C
« Reply #2 on: August 06, 2014, 08:03:28 AM »
I have a K75C with drum brake. Is there a K100 model out there with a drum-brake FD that will give me a lower gear ratio/higher top speed?
Offline K75RT Keith
« Reply #3 on: August 06, 2014, 08:53:00 AM »
Other than the number of splines changing, ALL the K series disc brake Monolever FDs are interchangeable.  ONLY differences are gear ratio and finish.  I don't remember a K100 with a drum brake in the U.S.  So, short of converting to a rear disc system, you may have limited options.
1990 K75RT
Offline Mongrel
Re: New question - how much does a final drive unit weigh?
« Reply #4 on: August 06, 2014, 10:20:07 PM »
One more question. Does anyone know how much a final drive unit weighs (closed, dry) approximately?
I'm guessing maybe 20 lbs? Can't be much more because it clearly weighs less than the transmission and I know that weighs 35 lbs or so.
'86 K75c
