Author Topic: Gear Indicator is Reversed  (Read 6970 times)
Offline Justdirt
« on: July 20, 2014, 12:43:46 PM »
 :yow I reinstalled my Instrument Panel.  Everything is working correctly except the gear indicator.  First Gear is now showing a " 5".  I would appreciate any suggestions on what I can do to correct the problem.
Re: Gear Indicator is Reversed
« Reply #1 on: July 20, 2014, 01:17:11 PM »
You have probably bad connection at the yellow/white wire at pin #2 at the cluster connector.
Then you would have strange numbers in all gears exept #4.
Offline Justdirt
« Reply #2 on: July 20, 2014, 01:56:23 PM »
Thank you.  I will pull the cluster connector and inspect.
« Reply #3 on: July 20, 2014, 02:10:57 PM »
The problem could of course be elsewhere in this circuit, but most likely at the cluster connector as you
just had it reinstalled.
The yellow/white wire should be connected to ground (at the gearbox switch) in all gears (also neutral)
exept fourth and fifth.
Offline Justdirt
« Reply #4 on: July 20, 2014, 03:27:23 PM »
Hello Norway, home of the World Chess Champion Magnus Carlson!  Thank you for the help, my cluster is repaired.  Have a great week.
« Reply #5 on: July 21, 2014, 11:07:17 AM »
Amazing...how could anyone know so much about anything?
Sorry...this post has so informational value except to marvel at Inge's infinite Kbike knowledge.
Offline Uffda
« Reply #6 on: July 21, 2014, 06:18:37 PM »
 :2thumbup:
...except to marvel at Inge's infinite Kbike knowledge.
  • New England
  • 1995 K75RT
Robert
Offline blakey
  • Learn to listen, listen to learn.
« Reply #7 on: July 21, 2014, 10:33:28 PM »
I've said it before and I'll say it again, Inge is a machine and not a person!  :dunno2:
Don't let the cute looking avatar fool you...
blakey
K100RS 1986 RED!
North of Bris Vegas, Queensland, Oz.
« Reply #8 on: July 22, 2014, 06:02:19 AM »
