Author Topic: Rear master cylinder leak  (Read 4114 times)
Offline MEL
  • 95 K1100LT
« on: July 19, 2014, 10:03:08 AM »
 My rear master cylinder is leaking slightly. I have read tht cleaning might stop the leak vs  new kit. What I havent seen referenced is if bleeding is required after this. I would think it would be. Are these ABS II rear brakes difficult to bleed....
Thanks
Mike
Imagine that.
1995 k1100LT
Re: Rear master cylinder leak
« Reply #1 on: July 19, 2014, 12:15:53 PM »
Mel,
FWIW - When my rear master cylinder leaked and finally ruptured one morning while riding, the wind blew the brake fluid onto my rear shock and destroyed the shock's seals. I had to replace the shock and master cylinder. Fix it soon.
Offline K75RT Keith
« Reply #2 on: July 19, 2014, 03:53:09 PM »
Rebuild or replace now. When it fails it will cost a whole lot more the taking preventative action. Besides that, brake fluid will destroy the paint on the frame.  Yes, you will have to bleed the rear. There should be a guide in the liberty or at ibmwr site
1990 K75RT
Offline Zipster
« Reply #3 on: July 19, 2014, 09:42:10 PM »
ABS2 is no problem to bleed
  • Northern Ireland
Offline MEL
  • 95 K1100LT
« Reply #4 on: July 20, 2014, 11:04:09 AM »
Thanks to all...I have it on the lift table.
Imagine that.
1995 k1100LT
