Author Topic: K100RS - Strange Tire Wear  (Read 13501 times)
1991K100RS
« on: July 07, 2014, 01:37:40 PM »
I noticed today that the front tire (metzler lasertec) on my 1991 K100RS was severely worn down, while other parts of the tire had not been nearly worn down at all. You can see in the picture attached that it has worn all the way down to the threads of the tire underneath the rubber. This wear pattern is ever 3-4 inches in intervals all the way around the tire. Tires probably don't have any more than 4k - 5k miles on them, bought them last year.
Before I go buying a new tire, I want to make sure the bike doesn't chew up another one.
Things I'm thinking could have been the cause;
- Low tire pressure for too long
- Uneven forks
- Wheel poorly balanced
- Bad front wheel bearings
Anyone else here have experience with such aggressive wear on a relatively new front tire?
Re: K100RS - Strange Tire Wear
« Reply #1 on: July 07, 2014, 02:02:22 PM »
thats how they wear... spots of cords... eventually all cords... flatlanders in the middle... canyon carvers on the edges...
1991K100RS
« Reply #2 on: July 07, 2014, 02:22:59 PM »
Thanks for the response. I just figured 2 rear tires for every 1 front tire.... and my front tire is even barely worn with 5,000 miles. Makes me think something isn't right in the front
« Reply #3 on: July 07, 2014, 03:42:17 PM »
for me... 2 for 1 generally 1up... 1.5 for 1 generally 2up... replacing as a set brings much yeeeehaaaa as both tiors have same newness... never did care for waiting on the front to shred... butts have done it before... more critical for canyon carvers compared to flatlanders...
Offline Bokobob
  • I am a 1936 Model
« Reply #4 on: July 07, 2014, 05:06:09 PM »
Conceivably wheel out of round?
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
1994 Honda Magna 750 V4
1996 Kawasaki Vulcan 500
« Reply #5 on: July 07, 2014, 05:13:18 PM »
whats the date code on the tior... rubber looks hard... how about some photos from a little farther away to get the big picture of things...
Offline Grim
« Reply #6 on: July 07, 2014, 06:49:04 PM »
I'd pull the wheel and see how the bearings feel. I had a shimmy feeling in my bike a certain speeds and the front wheel bearings cured it. Also when is the last time the fork juice was changed?
1995 Morea Green K1100LT
Offline harper
« Reply #7 on: July 17, 2014, 10:02:47 PM »
Don't forget that your tire will wear more on the left side due to the crown in the road.
Offline mjydrafter
« Reply #8 on: July 18, 2014, 08:56:48 PM »
Also your front tire will wear funny (compared to the rear) because of braking.  It's harder to spot on a smoother tread than a more aggressive tread.
More aggressive fronts, like knobbies for instance, will wear into a saw shape.
1986 BMW K75c
« Reply #9 on: July 18, 2014, 11:29:49 PM »
Yeah - That looks like old rubber.
Offline drut
« Reply #10 on: July 19, 2014, 06:43:13 PM »
Although maybe not helpful I cannot understand your tire choice,I have a 1990 K100RS16v & narrowed choice down to Michelin Pilot Roads or Dunlop  Roadsmarts:both radials & both greatly improve the bike/handling,why you would contemplate a bias belt rather than a radial is beyond me.
  • Newcastle upon Tyne UK
Offline K75RT Keith
« Reply #11 on: July 19, 2014, 09:04:35 PM »
what is the manufacture date on the tire?
1990 K75RT
