Author Topic: ABS Sensor Compatibility  (Read 5820 times)
Offline Zipster
« on: July 02, 2014, 04:23:14 PM »
Anyone know if there's any compatibility between 1996 K1100 LT rear ABS sensors and say 1998 - 2000 K1200 rear ABS sensors?
I'm still having issues and need a solution.
  • Northern Ireland
Re: ABS Sensor Compatibility
« Reply #1 on: July 02, 2014, 06:48:22 PM »
Well, according to the parts fiche, the late model 1100 abs pulse generator(after 7/93) is part #34 52 2 331 290
Fits some models K1200, but not all.
1200LT 06/97-12/03 euro
1200LT 06/97-11/03 usa (model year 99-04?)
1200RS 04/96-04/05 euro
1200RS 05/96-12/00 usa (model year 98-01?)
Sounds like you may want to research a little further the donor model.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline jacksdad1963
« Reply #2 on: July 03, 2014, 02:43:18 PM »
Ignoring the part numbers, I looked at the length of the rear sensor on my K1100, was exactly the same as a spare one I got from somewhere, so I just cut off the connector and fitted it....working perfectly so far  :2thumbup:
K1100LT 1995 mystic red
Yamaha XS650 1976 fully restored
a few cars and 4x4's
Offline Zipster
« Reply #3 on: July 03, 2014, 02:55:33 PM »
Thanks Mike - I may give that a go
  • Northern Ireland
« Reply #4 on: July 03, 2014, 05:31:04 PM »
Well it worked fine on my bike  :2thumbup:
I soldered the wires and heat-shrinked them, so don't expect any problems long term
« Reply #5 on: July 03, 2014, 07:07:12 PM »
Worked for me too when a mysterious fault appeared in the ABS cable...still good 50k later.
Offline Zipster
« Reply #6 on: July 04, 2014, 05:07:36 PM »
I get a 135(ish) ohm resistance through the sensor as per previous posts from Inge K.  I get a positive voltage reading from the loom plug (I can't remember what the value was) when the ignition is turned on. I can't figure where the problem is. I've tried both rear calipers / sensors and no joy. I'm going to try a third but if it doesn't register, I'm not sure how to properly test the loom. Any ideas?
  • Northern Ireland
« Reply #7 on: July 04, 2014, 05:45:40 PM »
Nope, sorry chap!
I'm next to useless with electrics, can just about do the basics with a multimeter  :hehehe
As I said before, I went for the simple approach and just grafted on a different part and it worked  :2thumbup:
