Is this front brake normal?
Topic: Is this front brake normal? (Read 4105 times)
F14CRAZY
June 30, 2014, 05:26:51 PM »
The previous owner said this bike has a "full floating" front disc...is that true? I also don't have a clue as to what that means.
Also, is there supposed to be something on the end of the axle on this side?
Grand Rapids, MI
'87 K75C
Zipster
^ Proficient Motobricker
Re: Is this front brake normal?
Reply #1 on:
June 30, 2014, 05:35:43 PM »
Look very similar to my K1100 LT brakes. The floating disc you have on the front means that any warping doesn't affect the braking as the disc is allowed to move.
The axle looks like mine too.
Northern Ireland
1996 K1100 LT SE - sold with 104,500 miles in 2015; 2001 R1150RT - 68,000 miles; 2013 Triumph Trophy SE - 50,000 miles; 2007 Harley Ultra Classic - 50,000 miles (Canada bike for stateside use only)
Add life to your days, not days to your life!
johnny
TrailBrakingThrottleWhacker
Reply #2 on:
June 30, 2014, 08:33:08 PM »
the disk is mounted the the wheel with bobbins which is a floater disk compared to the alternative... disk bolted to the wheel for a ridgid disk...
rbm
Reply #3 on:
June 30, 2014, 09:16:12 PM »
The axle looks normal. The hole can be used to apply rotational torque to the axle when removing/installing it. For example, I'll use a long bar through the hole and twist back and forth while pulling to withdraw the axle.
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
Zipster
Reply #4 on:
July 02, 2014, 11:29:03 AM »
As I said - it looks pretty much like mine!
Northern Ireland
