Author Topic: an uninteresting story  (Read 8698 times)
rsexauer
« on: June 24, 2014, 06:53:50 PM »
This morning I look at my oil level sight gauge and do not see any oil level, try cleaning still no go. I think to myself, self how else can I verify my oil level. Self says pull off the fill plug and stick a dip stick down there. Well it doesn't look like I can get anything far enough down to verify any oil. So as easily distracted as I can get I determine there is no way the oil level is too low, I verified the last ride that the oil level was good, very small rear seal leak not so much that it can't wait until this winter and I can plan some down time. See how easy it is for me to digress. Anyway I hit the starter without using the choke, temps in the low 80's it starts then dies, try choke and restart, very low ruff idle. I repeated starting and whenever I give it a little throttle it dies. Finally able to have a slow idle and am able to tickle the throttle enough to hit the road. I fight with the throttle for about 6-8 miles of city driving, stop - start motor dies restart etc., etc., etc. Finally I look down and realize that I never replaced the fill plug. Some oil on the bike, pant legs etc. Pull into Advance Auto parts and purchase a temp rubber  plug stopper, wipe up oil mess and back on the road. Notice right away the bike is running great, like normal. The missing drain plug must have caused excess/loss of pressure/vacuum in crankcase breather to air box.
The moral of this story is to listen to your bike it talks to us and we need to learn to listen.
I hope my wife doesn't read this
Re: an uninteresting story
« Reply #1 on: June 24, 2014, 07:24:07 PM »
greetings rsexauer...
dudes whack... im thinking by more than just a sip...
rsexauer
« Reply #2 on: June 24, 2014, 07:26:35 PM »
My fav Yuengling
Offline F14CRAZY
« Reply #3 on: June 24, 2014, 08:28:55 PM »
I started my bike after changing its engine oil and forgot to put the fill cap back...it did seem hard to start
  • Grand Rapids, MI
  • '87 K75C
« Reply #4 on: June 24, 2014, 09:26:21 PM »
Sounds funny too, sort of a huffing noise.
rsexauer
« Reply #5 on: June 24, 2014, 09:51:27 PM »
So I am not the lone ranger here, I did put the plug in the spares kit. Only $2.79 @ Advance  Auto.
« Reply #6 on: June 24, 2014, 11:42:46 PM »
It may also fit the hole if the sight glass pops out on you going down the road......... right CDB.... :2thumbup:
jacksdad1963
« Reply #7 on: June 29, 2014, 09:50:11 AM »
Will this bung also fit the radiator, or do I need 2 spare?  :hehehe
« Reply #8 on: June 30, 2014, 06:55:36 AM »
Yesterday I rolled out my 94 k75 for a test ride only to find that I'd neglected to torque the rear wheel lugs and radiator drain plug. Fortunately the motorcycle rides funny just before the wheel is about to pop off and the plug held on by a couple threads. There's a lot to be said for checklists...
rsexauer
« Reply #9 on: June 30, 2014, 07:04:02 AM »
The size range on the plug package said 1" to 1.125", I did not measure the hole dia. But expect you could cover a bit more range than the package describes.
Offline racinrich
« Reply #10 on: June 30, 2014, 08:37:09 AM »
I always check my nuts before a ride  :hehehe :hehehe
1993 k1100 lt silk blue
des plaines ill
USA
