Author Topic: speedo error check  (Read 9131 times)
rsexauer
speedo error check
« on: June 22, 2014, 06:52:31 PM »
This is my first post, had my 88 K100 for about 500 miles now and loving it. Where have you been all my life?
From what I have been reading excessive speedo error appears to be the norm. My experience as best that I recall is that on my bike I am turning about 4000 rpm's and the speedo is showing 70 mph and I am being passed on a regular basis. Is there an expected mph reading at a given rpm that I can compare to? I realize that engine tune may affect the accuracy but on a comparable bike with the same final drive ratio as mine I would expect similar mph/rpm ratio.
Re: speedo error check
« Reply #1 on: June 22, 2014, 07:21:44 PM »
First of all, don't ride/drive at the speed limit, ride at what traffic is going. It's much safer.
In general, it is exactly 10% fast. 80mph indicated is 72 mph actual. It depends on your bike's setup/FD ratio, but with a 3.2:1 final drive on a K75, 6000rpm is 80mph actual.
There is an app, Karamba, somewhere here or on flyingbrick.de you can use to calibrate.
rsexauer
« Reply #2 on: June 23, 2014, 05:27:06 AM »
I believe my FD ratio is 2.91:1, I was hoping someone with the same set-up would know the error corection value to see if mine was off enough to get into troubleshooting and correction if needed.
« Reply #3 on: June 23, 2014, 03:32:19 PM »
I'd put money that it is off. They are specifically calibrated like that from the factory, so far as I can tell. I guess that way they never show slower than actual, even with larger tires.
http://www.largiader.com/articles/gearing/
If you have the gauges off anyways, then is the time to adjust it. You can replace the lights with LED's too.
