Author Topic: 95 K11LT engine kerthunk  (Read 18091 times)
Offline Grim
Re: 95 K11LT engine kerthunk
« Reply #25 on: July 03, 2014, 07:31:54 PM »
Keith are you talking about the return line that exits out the front bottom of the fuel rail?
I did have a lot of problems with the return had to keep trimming it till I got it just right. If my local dealer had it in stock I would have bought it.
The 4 port line on the back of the throttle bodies had leaks where it joined each throttle as well. $75 hose :( I took some high quality hardening gasket goop to seal it up. Seems to be holding. It doesn't pull a lot of vacuum as it's above the blades. See how it does.
Did get in some miles today...different bike!  I had some back fire on decel  I had been writing off as TPS that it seems to have mostly cured. Much smoother overall.  Wish I had done this last year when I bought the parts.
1995 Morea Green K1100LT
Offline racinrich
« Reply #26 on: July 04, 2014, 04:50:26 PM »
worn bearings in the alternator,bin there done that, find a local alternator starter rebuilder ,its the same alternator  as an old land rover but a different drive,cost me 45.oo  my guy had parts in stock also checked brushes ,ok at 110k regulator output ok . done in a couple of hours
1993 k1100 lt silk blue
des plaines ill
USA
Offline ICBMW
  • All Season Rider
  • Replaced a 530i with a K1100LT
« Reply #27 on: February 26, 2015, 12:23:28 PM »
You know what it was? It was RUST coming off of the rusty gas pump and through the engine because there was a hole in the filter. The kerthunking went away when we cleaned the rust off and replaced the internal gas filter. Thanks all!
  • Arlington, VA
  • Purple 1995 BMW K1100LT named Pōni with the license plate ICBMW
