Author Topic: What Did You Did To Your Motobrick Today ?  (Read 2998821 times)
Offline Lenn0x84
« Reply #900 on: May 28, 2013, 07:13:10 PM »
Alright, so rode into work yesterday and about 2 minutes from work the clutch cable popped out of the lever, my fault. When I replaced the cable I had the cylindrical fastener but didnt think it would fit? (thats because I'm an idiot and too nervous when doing these things on my own for the first time :-S). Anyway 2 second fix, alls good and the way it should be.
Q# is the catch poibtt for the clutch a personal preference or is there a minimum lever release distance?
Anyway rode to my mates place, tightened the HS (headstem), rebled the brakes and adjusted the tps. Wow the tps makes a difference. The bike feels much better with th HS tightened properly ;-)
Loaded a few night time street shots after work was done.
https://www.dropbox.com/sc/46k6ko75i4kqth2/lBFBAvHiwW
.........1985 K100 - "Silver Brick".........
New to the scene, Old hand at the soul
Offline mjydrafter
« Reply #901 on: May 30, 2013, 02:16:43 PM »
Took an executive lunch and slapped a new BS Spitfire on the rear to match the front I put on earlier this spring. :yes
Less than an hour start to finish, and I spilled my airsoft bb's... :dunno
 :bmwsmile
Edit: (I guess executives probably don't change their own tires...)
1986 BMW K75c
Offline argent brick
« Reply #902 on: May 31, 2013, 09:05:07 AM »
Isn't your fairing off of a R80 or a R65?
Yep, and I've also seen it on a R45, but I think that may have been Euro-only as I can't find it in any fiches.  Google image search on those 3 will pull them up.  But I don't know if it's factory or aftermarket.  I believe I have seen one like it on E-bay in searching.  Don't know that it's rare or anything, but maybe scarce is a better description... :dunno
It's factory.  Part# 46 63 1 240 822  Covering Cockpit   $228.08
Duncan's Beemers had a used one a while back. They were asking $174 greenbacks for it.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline tsbt
« Reply #903 on: May 31, 2013, 09:55:00 AM »
Check this: http://www.motobrick.com/index.php?topic=332.0
92 K100RS 4V
75 KE125
« Reply #904 on: May 31, 2013, 09:54:57 PM »
Fork gaiters from kBikeParts.com.
Offline rocket23
  • bmw ride on!
« Reply #905 on: June 02, 2013, 03:37:45 PM »
 bought a set metzlers.....v. rated,....me's for the front, and lazertec for the rears.....riding on a plugged rear tire, and the front has a season left ......after this season they are coming off. also having issue's with my after market mirrors......(I can't seem too tighten them down on the swivel ball.........permatex too the rescue!
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out, and screaming,'WOO HOO! What a ride!'"
« Reply #906 on: June 02, 2013, 10:59:31 PM »
Grub screw. Took toooo long. Bugger better never come lose again.
Full spline lube too.
Offline rocket23
  • bmw ride on!
« Reply #907 on: June 03, 2013, 12:23:02 AM »
 Excuse my ignorance,  whats a  ''grub screw''??
Offline Lenn0x84
« Reply #908 on: June 03, 2013, 04:02:37 AM »
Anyone want to know what a k100 sounds like with the exhaust cut in half?  :lets-eat:
Check the link in my signature  :mm
Offline sh00ter
« Reply #909 on: June 03, 2013, 07:08:47 AM »
A small screw, usually a hex head that is uniform circumference and threads from top to bottom. Typically the end of the screw is used to hold something in place via direct pressure against it.
'94 1100 RS
« Reply #910 on: June 03, 2013, 07:23:18 AM »
Something that can come loose inside the K-bike transmission........ :yow
Causing head scratching, frustration, and results in transmission removal and dis-assembly to correct.
Offline sh00ter
« Reply #911 on: June 03, 2013, 08:59:19 AM »
<- +1
'94 1100 RS
Offline rocket23
  • bmw ride on!
« Reply #912 on: June 04, 2013, 12:02:47 AM »
You do know you just sawed off 325 quid? right?
Offline Lenn0x84
« Reply #913 on: June 04, 2013, 06:09:24 AM »
Thanks rocket, that fills me with enthusiasm to publish my project...
You realise theres nothing on YouTube that show curious people like me and builders what a cheap mod like this can do. I've also got a spare exhaust that I picked up for $50 aus (£31.62) incase, but I love this mod and this may come in handy for someone on a budget, or a streetfighter etc...
Who cares about the money when my bike gives me such a smile. And if someones thinking of doing this I'll be slapping a video with better sound soon.
Offline rocket23
  • bmw ride on!
« Reply #914 on: June 04, 2013, 07:52:54 AM »
I know, Lenn, no offense, mate. Talk about cheap mod's,Dodge has 2 hash marks on the front quarter panels of the challengers......Well I cut 2 strips of electrical tape and fitted them too the door handles of my Ram truck!.....Now thats cheap!,lol.
 I'm actuall gonna need some thing for my exhaust, it's showing it's age. I like the bogney cut exhaust, and the exhaust note is bettter than one might expect in your case. Good job. :2thumbup: :mbird
Offline tsbt
« Reply #915 on: June 04, 2013, 11:51:31 AM »
Just ordered a whole wack of bits, tranny seals and K1100rs fairing mounts so I can mod my K100rs to look like a dream machine  :2thumbup:
92 K100RS 4V
75 KE125
Offline branandfox
  • Loraine. K1050RS
« Reply #916 on: June 07, 2013, 03:39:29 PM »
Just did the same TSBT. All I got left is the paintjob I am currently saving for. then the remus pipe! corbin seat has yet to be made though... Still waiting on them to produce!
Hit the throttle and live.
Don't blink.
Don't slow.
Just breathe.
Offline sh00ter
« Reply #917 on: June 07, 2013, 08:34:25 PM »
Changed fork oil. Man that chit gets nasty. Balanced tb's.  checked brake pads and rotors.
'94 1100 RS
« Reply #918 on: June 09, 2013, 06:38:50 PM »
Well for the last week, the '95 is on the table for service.
Got all the oils changed, new tires mounted up, stripped down the front fairing assy to replace the steering head bearings.
I started by just cleaning them and see if that would help with "notchyness" but no dice. Still feel the notches with my fingernails so time to order bearing sets.
Have brake pads on order for both bikes and a rear rotor waiting for install on the '97.
Offline Lenn0x84
« Reply #919 on: June 13, 2013, 11:38:15 PM »
All Right!!  :riding:
Did some little service bits and pieces, cleaned and re-greased brake and clutch levers... Sooooo smooth now  :2thumbup:
Wanted to sync my tb's so I tried to build my own, but unfortunately will have to try again as it didn't turn out right, used 4mm tubing all the way but it looks like 4mm from vacum ports to 5mm tubing filled with oil would achieve a better result sooooo.
I decided to do it by ear  :yow all the screws where 3-4 turns out!! What have they done to this thing? Screwed them all down and came out 1 1/2 turns, much snappier and I'll toy around with it a bit more tomorrow, I think I'll try 1-1/4 turns and have a play until I re-build my Synchronizing tool.
Anyway thought I'd say what I've been up...
 :mm
Offline K75Slark
  • Das Fliegen Ziegel!
« Reply #920 on: June 14, 2013, 08:20:42 AM »
After chasing white rabbits in my fuel system, I checked my HES this morning with a hairdryer and she died when it got hot and ran when I cooled it off. Now I need to find the damn part somewhere online, I'm not going to give BMW a pile of money for a whole new assembly. I guess no :mm this weekend, oh well.
Anyone have a good lead for the HES plate?
'92 K75-Midnight Blue-~76k
Offline Lee Barker
« Reply #921 on: June 14, 2013, 05:41:31 PM »
This is pretty mickey duck but somebody had to do it:  I added a pad to my kickstand and discovered a jazzy way to dress the end of the foot hook:
Its the butt end of a putter grip.  Golf.  I happened to have on in the "very odd" drawer.  If I wanted another, I would go to a thrift store and buy a putter for a buck or two.  Slit the grip within about 2 inches of the end and it will all come off.  Trim it down, heat it in water if you need to, and slide it on.
The pad is a piece of 3/16 aluminum.
Both additions are functioning per plan.  It has been good.
Kindly,
Lee
Offline Kyle10
« Reply #922 on: June 17, 2013, 07:09:34 PM »
Scored a pair of engine guards off Fleabay for $165.
Gawd, if someone would replicate these relatively simple yet ever-rarer bars and brackets and sell them they'd make a tidy haul.
Now for the stripping, priming, painting, etc...  :2thumbup:
1985 K100rt
1983 Honda VF750F
The other 2% made it home.
« Reply #923 on: June 20, 2013, 04:35:37 AM »
Used a "Seal Mate" on my fork seals today. It seemed to work just fine. Simple too. Time will tell if it did the job or I have to tear into my forks. Keep your fingers crossed.
Lynn
1976 R60/6 RIP
Offline Grim
« Reply #924 on: June 20, 2013, 09:06:04 PM »
My seals just showed up but for $5 it's got my attention. Let us know how it worked.
Vid so others can see what this is.
1995 Morea Green K1100LT
