Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3588802 times)
Offline beemuker
« Reply #4075 on: May 24, 2021, 09:55:14 PM »
Figured I would share my shiny wheels.  I needed a new front tire and 20 plus years of existence had made the old paint show its age, I repainted the wheels.
Here's the K post final drive rebuild shake down ride..
looks good. I need to paint my wheels. What did you use?
  • Panama City, FL
Offline CTDOM!
« Reply #4076 on: May 24, 2021, 09:58:44 PM »
I used the VHT paint from Autozone.  Came out pretty good.  I first used Acetone to completely clean the wheels.  The used the VHT self etching primer for 2-3 coats.  Then the Silver VHT wheel paint for 3-4 coats, and lastly 2 coats of the VHT clear.  The kid at Cyclegear scratched it a little when mounting the new tire but oh well.
  • Central CT, USA
  • 1993 K1100RS, 2003 Ducati 999
Offline beemuker
« Reply #4077 on: May 24, 2021, 10:03:26 PM »
  • Panama City, FL
« Reply #4078 on: June 29, 2021, 08:08:25 AM »
Tire changeover using the zip-tie method, a quick brake pad change then back to the road rills, gullies and pothole fields my Brick calls Home.  :laughing4-giggles: A bath in the afternoon, probably.
« Reply #4079 on: June 29, 2021, 05:09:43 PM »
Yeek you need to invest 99 cents in a Bucket Flap.
Offline beemuker
« Reply #4080 on: June 29, 2021, 10:07:09 PM »
bucket flap?
  • Panama City, FL
« Reply #4081 on: June 29, 2021, 10:29:35 PM »
http://www.motobrick.com/index.php?topic=7914.msg57750#msg57750 Five extenda fendas and one dog bowl for 99c.
Offline beemuker
« Reply #4082 on: June 30, 2021, 08:28:03 AM »
got it. Are you still selling aussie buckets? I wonder if ,with shipping , it would be cheaper to get one from China?
  • Panama City, FL
« Reply #4083 on: June 30, 2021, 03:30:22 PM »
You need to go to the Buckets are OZ website. We have branched out and now do a range of Ned Kelly helmet kits in a range of colours.
Offline beemuker
« Reply #4084 on: July 01, 2021, 11:54:56 AM »
Incredible amount of trivia to be gleaned from these posts as many of these references are foreign to me. Ned Kelley helmet, check. bucket flap, check. 1 bucket = 640 oz. check .  112350
  • Panama City, FL
« Reply #4085 on: July 01, 2021, 04:15:14 PM »
We have branched out and now do a range of Ned Kelly helmet kits in a range of colours..
Sepia is the traditional color, still, there is room for earbuds in them but don't count on them to be bulletproof.
« Reply #4086 on: July 01, 2021, 07:27:17 PM »
With a Ned Kelly helmet if you seal up the vision slot it eliminates the need for a mask.
« Reply #4087 on: July 02, 2021, 07:05:22 AM »
You couldn't ask a bloke with a beard like that to wear a covid mask, that'd be worse than highway robbery.
Offline dbamberger
« Reply #4088 on: September 14, 2021, 11:56:03 PM »
Bought a 1994 RT on Friday.  It had a sticking throttle so I pulled it apart, cleaned it with some gas and an old toothbrush, put some white lithium grease on in there and it's silky smooth and returns with a snap.
  • Portland, OR
  • 1994 K75RT
Offline Past-my-Prime
« Reply #4089 on: October 03, 2021, 10:07:44 PM »
Not today, but over the past six weeks or so:
Disassembled and reassembled the water/oil pump combo because it was leaking oil. After that it stopped leaking oil and started leaking coolant. I thought I'd fucked up the coolant seal but after a test ride the coolant leaking has stopped, maybe it just needed to be set in but use?
Also did my first ever valve shim job. All the exhaust valves were too tight, went from 2.50 or 2.55 to 2.45 and they're all nicely in spec. now.
Refreshed all fluids including the fork fluids (that was grungy looking stuff, surprisingly!)
Replaced drive shaft and FD with units sold to me by Volador (Thanks Golja!!) and lubed the heck out of them.
Put an LED headlight in place of the halogen that had burned out the low beam.
Took the bike for a ride and fell in love all over again.
But since I'd been riding my F650 for most of the summer, I forgot how sweet the K75 is to ride.
« Reply #4090 on: October 03, 2021, 11:46:09 PM »
Which brand and model, PMP?
« Reply #4091 on: October 05, 2021, 10:22:28 PM »
SEALIGHT H4/9003/HB2 LED Motorcycle Headlight Bulb,3200LM 25W High/Low Beam Motorbike LED Front Head Light, 6000K Xenon White
Manufacturer: SEALIGHT
Sold by: SENLITE
Return eligible through Oct. 30, 2021
CDN$ 49.99
Condition: New
What I liked: exact fit, no moving parts (no fan) and some reviews that seemed to set it above others.
What I did not like: I had to cut the rubber boot behind the light because the stem of the light is longer than the OE halogen bulb.
Now, having used it (today) I am quite impressed by the light it casts. Much brighter than the old light, and in a bluer tinge which seems to provide more detail.
What I did with my Brick today: 500 miles shakedown cruise (needed to go to another town for work, 250 miles away on 2-lane highways). Bike ran fabulously!
« Reply #4092 on: October 05, 2021, 11:27:59 PM »
Thanks for the information, PmP.  112350
Offline motohippy
« Reply #4093 on: October 15, 2021, 04:54:52 PM »
Not exactly today, but since I was last here...in 2011...
Changed out the '88 motor for a '92 with all new rubber bits.
Paid someone to clean the injectors
Replaced the oversprung and clapped out Koni rear with a Wilburs (Best. Change. Ever. Like a new bike.)
Learned that 7.5w fork oil makes my S forks happy.
Put on a Corbin seat.
Put in a 55/100W Hella headlight, and the Eastern Beaver relay kit to feed it.
Finally sprung for a new instrument circuit board.
Wore out a few sets of tires...
  • SE PA
  • '88-ish K75S
Offline 2ruble
« Reply #4094 on: April 21, 2022, 01:26:53 PM »
Not today, but two days ago... I drove eight hours one way and bought  93 K1100LT, lol. Now, to decide if I'm going to try and bring it back to its glorious touring state or cafe it...
  • Loganville, GA
  • 1993 K100LT
« Reply #4095 on: April 21, 2022, 01:41:42 PM »
Welcome!
Restore it and it will take you to the west coast and back in comfort.  Cafe it and you might make it to the other side of town.
Agree Agree x 2 View List
Offline Supershooter
« Reply #4096 on: April 21, 2022, 01:48:33 PM »
Just getting started again, it’s been 2 years. Prep for paint.
  • 85 K100 RT
« Reply #4097 on: April 21, 2022, 03:26:01 PM »
WelKome
Got pics?
What is "unglorious" that needs fixin'?
Offline Barrieb
  • I just keep coming back to Bricks!
« Reply #4098 on: April 30, 2022, 08:32:17 AM »
I got the old pimpmobile (Gold K100LT) tested and taxed and took her out for a good run!
I'm well impressed compared to the RS I had a few years ago:
1. I can manouvere the bike in and out of the garage - even on gravel
2. I cant even feel the vibrations i used to remember on the RS
amazing the difference higher bars make and the bike still sticks to road like glue - love it!
  • East Anglia UK
  • 1987 BMW K100LT a Golden Oldie
Marge: Its easy to critisize
Homer: Fun too!
« Reply #4099 on: August 23, 2022, 02:56:09 PM »
I finally bit the bullet and replaced that flimsy center cover under the windshield on my K75RT along with the spider that supports the fairing.  The fairing is now centered like it is supposed to be and doesn't flop around around in the wind(one of the spider's arms was broken).
The center cover seems to have suffered greatly from exposure to sunlight and crumbled when I removed it to replace the spider.  I suppose I could have made some more repairs to it, but I figured it wouldn't last for one more removal, and who knows when it won't be available in the future.  On the plus side, the new one seems to be slightly thicker and less flexible than the old one.  The different surface finish on the part leads me to think that the production tooling may have been reworked or even replaced.  While the part may be marginally stronger now, the matte surface finish isn't as nice as the old one.
