Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3220592 times)
Offline Soggz
« Reply #3850 on: September 16, 2019, 05:46:17 AM »
Need to lube those nipples
Agreed, but aluminium STILL wears against hardened steel. The grease just turns it into a mild cutting paste.
  • Down in Selwood Forest
« Reply #3851 on: September 16, 2019, 07:17:44 AM »
Which part is the hardened steel?
Offline Soggz
« Reply #3852 on: September 16, 2019, 09:12:54 AM »
The barrel, apparently.
« Reply #3853 on: September 16, 2019, 08:51:05 PM »
Why?
Well, in the case of my lever, the hardened steel nipple/barrel, has worn out the softer aluminium lever hole where it sits. I.e, it’s not round anymore, so now it’s a ‘sloppy’ fit. I’m sure not everyone’s is like this, but it is 30+ year old aluminium under a lot of friction. Yours may be in a better state, but an older one like mine, will eat clutch cables over time. I’ll take some pics of new V old when I get it, for comparison.
Once a year, grease the barrel that holds the nipple in the clutch lever so that it rotates freely when you pull in the lever. It's an imperfect design but keeping the rotating part lubricated can prevent it causing you trouble.
Offline Soggz
« Reply #3854 on: September 17, 2019, 02:38:24 AM »
Hi. I realise this, and I will grease it for as long as I keep the bike, but I don’t think that the 12 previous owners before me bothered to!
« Reply #3855 on: September 17, 2019, 03:56:15 AM »
I'm still on my 1992 OEM cable. Every service I grease both nipples and the lever wear surfaces. I've fitted a grease nipple to the clutch arm and this gets greased twice a year. And I also flush and lube the cable twice a year with PTFE lubricant which is safe with the OEM Teflon lined cable.
Offline Filmcamera
« Reply #3856 on: September 17, 2019, 07:31:46 AM »
Installed OEM Low Seat Kit from Eville Rich.  Great outcome.  Dawn patrol tomorrow with lower c/g and new radial Battlax T30s.  Question to those w low seat: latch actuator rod seems 1/2 inch too short.  Is there a parts diagram out there showing a fitting for the threaded end?
Here is the parts fiche from Max BMW
I have a low seat on my bike and the actuator rod is a little short on mine as well.  It does fit and does work but only just...
  • San Jose, Costa Rica
Poserbricker
Offline Skunky
« Reply #3857 on: September 17, 2019, 08:32:21 PM »
I Made a modification to the side stand today. The purpose of the modification is to ........
1 - Reduce the angle and weight of the bike on the stand.
2 - To allow the bike to be lowered onto the stand while your still sitting on it
My K had a spring loaded side stand which came up, with force when the weight of the bike was lifted off. It also seemed to lean a long way over putting a lot of weight on the stand and making it unusable on a camber. It was virtually impossible to put the bike on the side stand when sitting on it because to hold the stand forward you had to take your weight bearing foot off the floor. Therefore you had get off the bike before you put it on the stand, balancing the bike and performing the Rudolph Nureyev arabesque required to get off is not the easiest or most graceful dismount.
Anyway. Shortening the side stand bolt allows the stand to stay down once put there and making a foot extension hardwood and a thick rubber pad reduced the angle to lean.
Job Done.  :twothumbsupp
* Stand1.jpg (48.79 kB . 432x576 - viewed 872 times)
* Stand2.jpg (47.25 kB . 437x576 - viewed 885 times)
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Offline beemrdon
« Reply #3858 on: September 17, 2019, 09:44:08 PM »
A Hocky Puck Lean Angle Solution...(not my original idea)
I drilled a small hole through a hocky puck, then ran a length of para cord, aka string,  through it and secured it with a square knot. I made a loop at the other end. Done.
When necessary, I take the puck out of either the tank bag or the empty fairing pocket where the shitty radio used to be (LT). Then I drop the puck onto the ground and put the side stand leg on top of it. Next I place the loop end over the left side handlebar as a reminder that it is there.
Makes the lean angle a lot less and doesn't sink in loose surface.
(sorry, too lazy to go and take a pic)
Offline Nine80seven
« Reply #3859 on: September 18, 2019, 12:10:07 PM »
How does the extension not interfere with the center stand when retracted!  Awhile back I added a little to the bottom of the side stand KRS '84' and it interfered with the center stand, so it was removed.  Now I'll have revisit this task.
  • MN
  • 85 K100RS
Offline Soggz
« Reply #3860 on: September 18, 2019, 02:18:05 PM »
Lots this evening. Fitted the ‘proper’ rear rack, and new clutch lever and pivot bolt. Clutch now loads smoother. Greased with home made moly grease.The wear in the lever is evident, hence the ‘up and down’ slop, which has now vanished.
« Reply #3861 on: September 18, 2019, 03:19:42 PM »
Do you know how many miles had been racked up on that relic before you got a hold of it?
Offline Soggz
« Reply #3862 on: September 18, 2019, 03:57:04 PM »
the speedo said 78,000+ When I got it last September, but the previous owner said that the original speedo broke and was replaced with one that had 10000 miles more on it. I’ve done 1000 on it since the 1st of June this year.
Offline Skunky
« Reply #3863 on: September 18, 2019, 08:26:41 PM »
Admittedly when I use the centre stand I have to push the side stand down first and again when you take it off.  Less of a problem that the excessive lean.
  • Derby GB
« Reply #3864 on: September 18, 2019, 08:57:44 PM »
I used a piece of boat roller and a 5" inch post cap for soft and sandy ground. A mate used a 6" X 6" piece of aluminium on a cord for soft ground.
* BMW Side Stand Spacer.jpg (21.2 kB . 431x288 - viewed 952 times)
Offline Skunky
« Reply #3865 on: September 18, 2019, 09:02:13 PM »
And do you get clearance Clarence?
  • Derby GB
« Reply #3866 on: September 18, 2019, 10:33:01 PM »
nice! quite a difference between the old and new levers.
« Reply #3867 on: September 19, 2019, 01:35:43 AM »
Side stand needs to be deployed first and retracted last.
Offline Soggz
« Reply #3868 on: September 19, 2019, 02:34:55 AM »
yup. More of a pleasure to ride
Offline natalena
« Reply #3869 on: September 20, 2019, 06:39:17 PM »
Twisted Throttle has the SW-Motech bar riser for K bikes on sale. Got a set for about $65.00 (bar=22mm, H=30mm, Back=21mm), and they shipped super fast.
The kit is very nice with plastic plugs to detail fill the hex head bolts. Parts were individually packaged to avoid scratching...which happened on installation anyway.
The stock K75S front brake hose is long enough and just needed to be loosened and pivoted a bit. All other lines had ample length.
Ended up fabing up asymmetrical brackets to avoid any rub on the brake hose, keeping in mind full-lock clearance for the tank cover if used.
Mirrors adjust fine, and the slightly more upright posture is much more comfortable, especially on the wrists/forearms. GPS moves up a bit and blocks the low-gas and "choke" lights a little, although they can still be noted when lit.
Cheers!
  • MST
« Reply #3870 on: September 21, 2019, 11:48:01 AM »
hey mang is this a 32 year old rubber brake line...
 :smoke07
just saying mang...
* brakefail.png (30.27 kB . 540x576 - viewed 917 times)
Offline Soggz
« Reply #3871 on: September 21, 2019, 12:12:40 PM »
Cheers!
They look good. Wouldn’t mind some, myself.
Offline natalena
« Reply #3872 on: September 21, 2019, 04:01:09 PM »
 :smoke07
just saying mang...
Good eye's! Yep, 100% authentic BMW original source. I plan on upgrading the lines when I change out the original 78k mile front brake pads, but so far they're stopping great, as long as you plan in advance and keep a thumb on the horn ready.
  • MST
Offline Skunky
« Reply #3873 on: September 22, 2019, 02:30:58 AM »
  • Derby GB
Offline ScooterNSticks
« Reply #3874 on: September 23, 2019, 07:14:30 PM »
I removed my instrument cluster on the K75 this morning, packed it up and shipped it off to Overseas Speedometers in Austin, Texas.  The odometer and trip odometer quit working.  While they have it apart they'll replace the burned out illumination lights as well.
  • Boalsburg, PA
  • 1992 BMW K75, 2006 Vespa GTS 250ie
My Blog: Scooter in the Sticks
https://scooterinthesticks.com
