Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3221223 times)
Offline beemuker
« Reply #3325 on: September 25, 2018, 09:00:36 AM »
got my top box re keyed and mounted. cost me $15 at a local locksmith to get the lock to work with my ignition key. One key for all, woo hoo. but does it make my butt look fat? it's awfully handy . Notice my 12"  screen for more air [It's finally cooling off , only up to 85F yesterday. And how about those sticky tires that allow me to park like that on any wall!
  • Panama City, FL
« Reply #3326 on: September 25, 2018, 10:48:44 AM »
ooooh, all that real estate to put stickers on!
Offline beemuker
« Reply #3327 on: September 25, 2018, 11:00:56 AM »
maybe just a back off, but once you get started...
  • Panama City, FL
« Reply #3328 on: September 25, 2018, 11:08:34 AM »
Mine pretty much hold the bike together.  Need to find one for the right rear blinker before it falls off.
« Reply #3329 on: September 25, 2018, 11:30:22 AM »
:giggles
Offline Skunky
« Reply #3330 on: September 25, 2018, 01:29:05 PM »
If anyone can see your butt past that box then yes   :hehehe
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
« Reply #3331 on: September 25, 2018, 05:55:19 PM »
Prepped the 92 K75S for a track weekend.  Flushed brake fluid, deleted mirrors, rear turn signals and rear foot pegs.  Checked rest of fluids and set tire pressures.  Still need to stick some gopro mounts on it!
K13S is going to the track and got done work also, but it ain't a brick!
Gonna get some YEE HA!
« Reply #3332 on: September 25, 2018, 06:14:22 PM »
Scott, do you mean the Bridgestone A41 radial?  They look very interesting.  I really like that they aren't semi-knobbies, but have what looks like a road tire tread pattern.
I might finally be able to put radial tires on my K75RT!
https://www.bridgestone.com/products/motorcycle_tires/products/detail/pr142/
Yea, I must have fat fingered it.... I edited my post.
I like that they aren't semi-knobbies as well. They seem pretty decent thus far... time will tell.
They showed up fast as well... I asked for standard 3-8 day shipping.... had them in less than 48hrs...
I got the e-mail saying they were "out for delivery" before I got the email that even said they were shipped.... lol.
Offline Filmcamera
« Reply #3333 on: September 25, 2018, 06:25:49 PM »
I have my first ever track day on my K100RS in a couple of weeks.  Do you have any brick specific tips or tricks for a day of yea haa on a 28 year old bike?
  • San Jose, Costa Rica
Poserbricker
« Reply #3334 on: September 25, 2018, 09:33:58 PM »
make sure tires, brake pads and brake fluid are fresh.  start off with 3-4psi lower pressure in the tires than you normally run.  make sure you and the bike are totally ready the day before the event.  do not leave ANYTHING for the last minute.
at the track...start slow.  listen to the instructors.  work on being SMOOTH.  don't just try to go fast.
K's are long heavy bikes.  they are a workout to get around a track....
three rules for track days...be safe...have fun....improve your skills.
(although i am a student at MC track events, I am a long time competition and performance driving instructor in cars...)
Offline Filmcamera
« Reply #3335 on: September 25, 2018, 09:38:21 PM »
Great thanks, yep that is pretty much what I had in mind, I am going to go gently on the old girl to start with - and probably to end with as well lol.
There will be some instruction available there, but mainly I am looking forward to be able to lean the bike more than I normally do without worrying about horses, chickens, goats, potholes, sand and all the other daily obstacles that Costa Rican roads offer.  yawl
Poserbricker
Offline John Lang
  • John Lang
« Reply #3336 on: September 28, 2018, 08:53:54 AM »
I checked the valve clearances, confident they would be OK and I could ignore them for a long time. Alas, #1 exhaust is tight (0.2mm). Now I gotta buy that tool thingy, find out which shim is in there, order and install a new one. Rats!
  • Ottawa, ON Canada
  • 1987 K75C
« Reply #3337 on: September 28, 2018, 09:10:02 AM »
It can be done without the tool, just need to find something to lever the bucket down and hold it there.  But the tool makes it easier.
Offline John Lang
  • John Lang
« Reply #3338 on: September 28, 2018, 09:22:03 AM »
Thank you, Chaos. I may have a go without the tool and then reluctantly order it.
  • Ottawa, ON Canada
  • 1987 K75C
« Reply #3339 on: September 28, 2018, 11:37:09 AM »
Follow the diagram below. My experience is that it makes extraction of the shim easier. The slot is for the insertion of BMW's tool—maybe some type of plier or tweezer for which you have a substitute in your collection—that grips the shim for extraction when the bucket has been pushed down. A pick can be put in that slot to lift the bucket. I used a narrow, flexible magnet and a pick to position, pull and replace the shims.
To sum up the diagram, once the cam lobe isn't touching the shim, the bucket can be rotated so its slot is oriented per the diagram. To extract the intake shim, the bucket is pushed down on the right side of its rim then the shim is extracted from the lower left quadrant. To extract the exhaust shim, the bucket is pushed down on the left side of its rim then the shim is extract from the upper right quadrant. Once the shim is loosened from the bucket, sometimes gravity will extract it for you. The trick is to push down on the rim firmly and steadily enough without your pushing-tool slipping off it while the shim is being extracted to the background sounds of howling, cursing and moaning. :giggles The extraction tools eliminate the variables and lower the decibels.
I purchased Ken Lively's valve shim extraction tools when they were thirty-five bucks for the pair. There might be a pair kicking around up there that one of your compatriots could mail to you on loan. They're slim and don't need to be boxed—at least down here they don't.
Offline John Lang
  • John Lang
« Reply #3340 on: September 28, 2018, 12:04:06 PM »
You have cleared up my puzzlement, Laitch. Very helpful. Many thanks.
  • Ottawa, ON Canada
  • 1987 K75C
Offline bluebossa
  • K75 and R65 Owner
« Reply #3341 on: September 28, 2018, 05:09:39 PM »
I revved it to as near the redline as I dared - 8,000 RPM plus on a 3 mile highway dash to warm it up. Felt good, nothing went bang.
  • UK
  • K75C
Current Bikes: K75 (C) in the UK (1986), R45 (1981)
Former Bikes:  K75RT, K75S, R850R, K1100RS, Dnepr MT10-36, R1200GS, K100, R100T, R100RT.
BMW R45 and K75 Blog
Offline blackie1
  • christchurch nz
« Reply #3342 on: September 28, 2018, 05:31:56 PM »
aaahhhh....  nothing like an aggressive warm up regime
aren't you curious to know if your rev limiter is working?
please report back
  • 1991 K75RT naked 67,000kms
« Reply #3343 on: September 28, 2018, 05:37:02 PM »
 :giggles
« Reply #3344 on: September 28, 2018, 09:52:03 PM »
just get ken's tools.  they are cheap.  they work.  they eliminate damage to the buckets and make the job easier on the first try.
one thing i have learned in a life of wrenching....use the right tools for a job.  they are worth the investment.
« Reply #3345 on: September 28, 2018, 09:56:40 PM »
read a few books on performance riding before you go, or there is a Brit who has a great YouTube channel with a series of 5min videos on a bunch of starter track topics.  channel is "LifeAtLean"
https://www.youtube.com/channel/UCzjILZxaqNI0FM_XPPkcRJw
Offline Filmcamera
« Reply #3346 on: September 29, 2018, 07:05:53 AM »
Thanks Mlytle, I have got and have read both Total Control and Twist of the Throttle and have been watching life at Lean for a while, I am nothing if not prepared in theory at least. That is partly why I want to try the track day, there is only so much you can do on a public road without being in serious danger  :falldown:
Poserbricker
« Reply #3347 on: September 29, 2018, 08:38:52 AM »
If part of the track-day training consists of avoiding chickens on the public roadway, let me know. Although I have always managed to maneuver around them, I won't hesitate to sacrifice them if necessary for the benefit of my well-being, despite being a vegetarian.
Along with some of the texts you've cited, I was taught—and I continue to practice—maneuvering and hard braking on less-traveled back roads, and using pylon arrays in empty parking lots. I've only one bike and one body so I'm conservative. Restoration of either will take longer at my age and riding season where I live is only six months long. :giggles
Offline bluebossa
  • K75 and R65 Owner
« Reply #3348 on: September 29, 2018, 12:20:37 PM »
Removed my crappy single horn and re-instated my Dual Fiam RT Horns - sounds like a Car again now!
Also cleaned inside 2 Starter Motors and fitted best to Bike
  • UK
  • K75C
« Reply #3349 on: September 29, 2018, 01:11:03 PM »
Old joke pops to mind, how can you find out if someone is a vegetarian?  You don't have to, they'll tell you.  Thank you Laitch for proving another stereotype is reality based! :clap:
