Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3589959 times)
Offline Skunky
« Reply #4000 on: April 21, 2020, 04:54:48 PM »
Stuck at home Covid Tuesday. Valve check and adjust . Oil and filter changed.
* 4E819A33-12C4-4BE3-B2EA-AA84798CBE11.jpeg (137.42 kB . 640x480 - viewed 1235 times)
* 5C503F9D-24A8-453D-ADAB-B60E5BE35A67.jpeg (33.45 kB . 432x576 - viewed 1222 times)
* 2C4502FA-B3F7-40E2-8ED9-0C992AE60149.jpeg (40.53 kB . 432x576 - viewed 1310 times)
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
Offline Barry in IN
« Reply #4001 on: April 21, 2020, 06:28:53 PM »
What I did to the K today?  I moved the ladder off the K75 that fell against it.
Luckily, it didn’t knock the bike over and it hit where the fairing was already scuffed, so I can’t tell that it did anything.   It now occurs to me I should’ve left the ladder there rather than risk giving it another shot.   Secure the ladder?  Please.  Don’t be silly.  This is how I learn.
  • Indiana
  • 1992 K75S Lili Von Shtuppe
A pox on cafe “builders”
Offline BlitzenGruv
« Reply #4002 on: April 21, 2020, 11:46:50 PM »
Today I renewed the heat sink paste on the ignition amplifier. I wasn't experiencing any trouble but i don't wish to.
I followed the excellent instructions in the technical section here, thank you.
I've found that, much like working on Japanese cars, it helps to have multiple lengths of tools in order to get around whatever is in the way of getting to a fastener.
BTW: I suggest one addition to the instructions for this procedure. Put some electrical tape over the positive battery terminal to avoid the probability of shorting the battery when pulling the Motronic box out of the frame.
  • Crossville, TN
Offline herseyb
« Reply #4003 on: April 26, 2020, 12:16:42 PM »
Well, I replace the hose with that runs from the rear brake reservoir to the master cylinder on my K1100RS.
I was surprised when cleaning the pins didn't solve my heating disc issue because I saw retraction in the cylinders when I had the caliper off the bike.
After getting the bubbles out of the new line, I slowly rotated the rear wheel and could hear contact for about 2/3rs of the wheel, with about 1/3 sound either clear or very quiet.
Now I am suspecting that perhaps the disc has too much lateral run out - maybe due to heating from the icky sticky slider pins.   So I guess I need to get a dial indicator...  at this point it's either new disc and/or rebuild the caliper.
  • Brooklyn
  • '93 K1100RS
Offline Scott
« Reply #4004 on: May 01, 2020, 07:08:49 PM »
Put a brand new Avon on the rear to replace the almost new one with a nail in it.  Still had 5.5 mm tread left.  I'll keep it around and use it on a tube bike application.
  • SoCal
Offline Past-my-Prime
« Reply #4005 on: May 02, 2020, 12:09:22 PM »
Would you ever run it with a plug in it?
Offline mw074
« Reply #4006 on: May 02, 2020, 12:39:43 PM »
I have run thousands of miles with a plug in the tire. Mostly due to picking up a nail or other when thousands of miles from home. The slightest sign of a leak after being plugged and a diversion to a tire store happens. I carry a small compressor and a plug kit with me always, Murphy's Law and all.
  • Michigan
« Reply #4007 on: May 02, 2020, 12:42:10 PM »
moto tiors flex too much to ride on a plugged tior for very long... unless you are the michigan militia of course...
* il_794xN.1757327329_p2j6.jpg (86.5 kB . 480x576 - viewed 1186 times)
and unless you ride like a pussy... pussy... grabb you some...
* download.jpeg (47.26 kB . 768x467 - viewed 1211 times)
Offline mw074
« Reply #4008 on: May 02, 2020, 01:55:41 PM »
That sounds like a challenge.
  • Michigan
Offline volador
  • NEEDS MORE CHROME
« Reply #4009 on: May 02, 2020, 03:23:04 PM »
oh man armchair challenge...
let me get a bowl of Lucky Charms...
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #4010 on: May 02, 2020, 04:10:26 PM »
The mushroom type plugs should be good...
Getts you some...
Offline Scott
« Reply #4011 on: May 02, 2020, 04:50:11 PM »
I wouldn't for long, just to get home, like I did with this one.  There are repairs that plug and patch from the inside, all in one whack, that are supposed to be fine to use permanently.  Maybe those would save buying a new tire.  The rope plug I used was holding air, but I'm never comfortable with a compromised tire.  After all, it's all I have between me and the tarmac. I have a use for the other tire that can use a tube, so all's good here.  112350
  • SoCal
Offline mw074
« Reply #4012 on: May 02, 2020, 06:15:21 PM »
I picked up a nail in the rear doing the Canadian Rockies. Did Banff to Jasper to Kamloops to Seattle before I could get a tire at Ride West BMW to ride back to Michigan.  Would I recomend it? No. Just saying that it can be done.
  • Michigan
« Reply #4013 on: May 02, 2020, 07:00:34 PM »
I've plugged tyres to get myself home and then had them mushroom plugged at a tyre shop, no problems. I've also heard of patches being applied from the inside, which in theory sounds alright. Some tyre shops will not plug tyres, probably due to fear of being sued if it fails. There does not seem to be any legal problems with plugging them in QLD.
« Reply #4014 on: May 02, 2020, 08:49:25 PM »
I plugged a tire from the inside and did track days and races on it afterwards with no issues - it depends where the plug is.  Mine was right in the middle of the tire so not too many issues with leaning etc
Offline Chri5
  • Buy it - Break it - Rebuild it!
« Reply #4015 on: May 04, 2020, 12:49:31 PM »
Refreshed my switch gear not quite finished but that's for tomorrow
  • United Kingdom
  • K100RS
Yamaha FZ6n-s2 electric conversion(Electric motor 240nm of instant torque)
Kawasaki Z750R
85 BMW K100RS
Buy - Break - Rebuild - Repeat!
« Reply #4016 on: May 04, 2020, 12:57:13 PM »
Nice work! What did you use to clean them, Chri5?
Offline volador
  • NEEDS MORE CHROME
« Reply #4017 on: May 04, 2020, 01:54:50 PM »
he use vinegar
  • NYC NY
Offline CTDOM!
« Reply #4018 on: May 13, 2020, 09:46:24 AM »
First time i heard the vinegar trick.
Last night I was able to remove the bolt that holds the front brake lever.  Took an easy out, two wrenches and many curse words..  Now to get the parts so the K's back on the road..
  • Central CT, USA
  • 1993 K1100RS, 2003 Ducati 999
Offline RobP
« Reply #4019 on: May 24, 2020, 09:41:37 PM »
I mounted and balanced a new Shinko 230 on the rear wheel.  Pulled the swingarm/final drive and driveshaft for a new coat of Staburags on the splines.   All splines looked great - with squared tops; no shark teeth.  Currently at 66K miles, hopefully good for another 66K.
  • Driftwood, TX
  • 1985 K100RS
« Reply #4020 on: May 25, 2020, 08:24:43 AM »
Nice job!  I am really liking those rim protectors.  Do you have a link to where I can cop a couple?  Those tire tools aren't too shabby either.
Offline RobP
« Reply #4021 on: May 25, 2020, 12:28:05 PM »
Quote
Revzilla.com among other places.   They are the MotionPro 'bead breaker' tire irons and the MotionPro rim protectors.  Not shown is Bullsnot tire lube available on Amazon.
See
  • Driftwood, TX
  • 1985 K100RS
« Reply #4022 on: May 25, 2020, 05:16:30 PM »
So those irons can break the bead!?  Do they work pretty well as a breaker?  I think I'll stay with my rim protectors, the ones in the video seem to want to pop off.
One thing about the video, I have found that the valve stem isn't necessarily the heaviest spot on the rim.  Now, I check the balance of the wheel without the tire and mark the heavy spot which I have found can be as much as 8 inches away from the valve stem.  Doing this check, has made getting perfect balance a lot easier.
Offline Rcgreaves
« Reply #4023 on: May 25, 2020, 10:33:22 PM »
I purchased and used these tools for the first time today.  Bead breaker is first rate and worth the Motion Pro $50 gouge...
Speaking of gouges the tire protectors didn’t... found myself wrestling to fish them
Out .. The big holes in the protectors are good for honking on them without breaking or tearing the rubber etc. my weight went nearly in same location.
Doing “better than I deserve"
« Reply #4024 on: May 26, 2020, 06:59:33 AM »
. . . the Motion Pro $50 gouge...
Members can forge their own before the weather gets too hot and save some money; if they do some extras, they can sell them at farmers' markets.  :laughing4-giggles:
