Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3444973 times)
Offline kryder
  • Realryder
  • Ryde ' em when I can.
« Reply #2175 on: July 04, 2016, 09:16:02 AM »
Funny.   My S came with those risers and with the bars turned up a bit.  Uncomfortable.   Ditched the risers and turned bars down to Master Yoda position.  Life is now good happily spinning 5300rpm on the highway!
To each their own. I like the riding position of the K75S and have owned two K75S motos. On the other hand I have a 2000 R1100S I am about to add bar backs to and will then lower the footpegs in an effort to make it a better long distance machine. On my K75 I am comfortable enough to travel across state lines, on my R1100S? Well, it needs some modifications.
  • Salida, Colorado and Park City, Utah
  • 1993 K75S
I live west and ski west, I ride east and west and sometimes north and south.
Motos currently owned,  or do these motos own me?
1993 K75S ( the Kryder )
2000 R1100S ( Blackie )
1986 R80RT ( Ole Red ) 1986 R80RT ( Ole Blue )
1994 BMW R1100RS ( Traveler )
Motos I have owned in the past; gone but not forgotten.
1964 Yamaha 55cc YJ1-K ( ringdinger )
1965 Yamaha Santa Barbara 125 ( ringdinger #2 )
1966 Honda CB160
1971 Honda CL350
1973 Yamaha RD350
1987 BMW K75T
1992 BMW K75S
1994 BMW R1100RSL
1978 BMW R100RS
Offline moto949
« Reply #2176 on: July 04, 2016, 10:34:00 AM »
Hi Mlytle
    True, when the bars are turned up wrong (like how I myself first had them set at a guessed-at angle for my first test ride after the riser install), they were feeling far away and cockeyed in relation to the seat/pegs. Not great. Then I angled them down a bit, test rode it, and was very surprised at the improvement - amazing how different they felt, falling naturally to hand. I went through the trouble of angling them down once more, barely a degree or three, and now I'm real happy I bothered to do it (remember, you'll need to loosen the underside allens and properly re-adjust the lever/mirror/signal assembly each time).  *I should add I'm 6'2", which may be why it works fantastic for me.
    Another factor are my suspension settings of a Progressive base model (4015) shock set on the highest preload for my 225 lbs to help steering, as well as the front tubes raised 4mm (to drop the front the same amount) which in combination nicely quickens the steering without reducing stability... so far. Those suspension changes will of course angle a rider down and forward slightly compared to stock.
Hi Dude, like your style (sick of hearing that yet?)
     What happens when you install the risers is the front/top cover (with the ignition and switches) goes up as well, so the underside brackets riveted to the rubber above, and screwed to the casting below, no longer reach. All I did, for now anyway, was zip-tie each side through the now-empty braket hole through handy slots in the lower casting. It's holding it more than snug enough for my needs. The other cover, on the backside, can still be installed as before, and tucks under just enough not to notice.
      Re the gearing, yeah, I know the engine can take it, but my friend, why dish it out?  My VFR 750 could also take it, but it would be like riding the Interstate on that bike in 4th gear. Why would we do that? No matter what I've read on all these forums, all a K75 is doing at those higher rpm's is burning more gas (I've seen in my multi-tank-by-tank test, an improvement of nearly ten percent better mileage, and not just going by the odometer, but actual city to city distances). Oh and you're also just breaking down your K75's oil's viscosity faster for nothing. I'm telling you with all honestly, this bike finally felt like grown up bike after the change, no longer so busy and straining. And remember, it's still right at its torque peak at highway rpm, perfect for passing. It's not lugging at all and it feels great.
      And it's not just on the highway where it's better - right after the change, which raises all gears proportionally, I was not thinking, "Hey, my bike is now sluggish."  I was instead thinking, "Yikes, first gear (and second, and third...) was so short before, the way it got used up in a blink was silly for this type of bike." I mean, if one wants to imagine his K75 is a performance bike, then yeah, technically you will accelerate a smidge faster with the shorter stock gearing and maybe you can just keep ahead of your girlfriend's Vespa 300 GTS.
      I believe that people have made negative comments regarding this gearing change have either never tried it, or have tried it on a K75 that may not be in its best state of tune. Our lovable, but old school K75s are weak enough already without riding them around without the throttles synched, the valves adjusted, the injectors cleaned etc. If you're hesitant about the 2.81 final drive, hedge with the 2.91 and enjoy!
Hi Kryder
    I'm happy you like your K75 but I always believe there's room for improvement - some improvements are worth the effort, some are too expensive or time consuming to be worth it. I'm happy with the changes I've made, but I'm happier if you like your bike as is. By the way, enjoy your 1100!
  • florida usa
  • 1993 k75s
« Reply #2177 on: July 04, 2016, 11:48:19 AM »
Did the risers make for a neat job?The plastic handle bar cover,is that used?
FWIW, I raised that plastic piece an inch or so with a couple bits of flat stock to get everything to look right with the risers
Offline The Dude
« Reply #2178 on: July 04, 2016, 02:46:47 PM »
Yeh,looks ok and the front one still blends in.
Thanks.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline The Dude
« Reply #2179 on: July 04, 2016, 03:00:13 PM »
Hi Moto,thanks.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline motorheadsdiygarage
  • Knowledge is Power
« Reply #2180 on: July 08, 2016, 07:30:05 PM »
Fixed the ABS problem with a used relay from Stuman. :2thumbup:
Great! No more flashing lights. :musicboohoo:
  • Near Montreal Canada
  • 1992 BMW K75S
« Reply #2181 on: July 09, 2016, 06:49:42 PM »
Left my 95 K75 by the side of the road, walked 1/4 mile home, hooked up my trailer, took its contents to the dump, then put my brick on it and brought it home. In 16 years and probably 130k miles, I've never had complete spline failure but I guess today was my lucky day. The good news is that it wasn't the new OEM driveshaft I just put in 150 miles ago or final drive splines. The bad news is that I have to pull the transmission to find out whether it's the clutch or transmission splines or worse. More good news -- it happened walking distance from my house. More bad news -- it was 95 degrees and humider'n chit and the whole thing sucked -- those clutch and transmission splines looked fine last time I lubed them with GD 15k miles ago, wondering if clutch alignment is a factor.
Offline ICBMW
  • All Season Rider
  • Replaced a 530i with a K1100LT
« Reply #2182 on: July 10, 2016, 10:28:32 AM »
Shameful cross post of my dirty dirty dirty dirty dirty dirty -- added some 20W50 today so all's well that's lubed well.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Arlington, VA
  • Purple 1995 BMW K1100LT named Pōni with the license plate ICBMW
Offline ICBMW
  • All Season Rider
« Reply #2183 on: July 10, 2016, 10:38:36 AM »
Added a 12x12 BeadRider Ultimate to my sawed-off Corbin Dual Canyon saddle.
Fellow MotoBrick MotoMadness 2016'ers can look forward to my sweet smelling aero-cooled butt in Utah and Coloradah later this month.  :ba:
Tell me more. Should I try some? I park outside. Will they endure?
  • Arlington, VA
Offline ICBMW
  • All Season Rider
« Reply #2184 on: July 10, 2016, 10:41:48 AM »
Ordered a new Parabellum windshield because I was too dumb to stop and figure out why my steering felt so heavy (front tire only 15 lbs of air) so went around the block to come in the back gate for a check. Unfortunately, staggered rock paving stones and low front tire pressure don't mix, so bike toppled, broke wife's shrubbery apart, and put a windshield out of commission. Oh well, live and learn (again)...
Damn! I'm going out right now to check my air pressure. This is a theme. The universe speaking, as Oprah would say.
  • Arlington, VA
« Reply #2185 on: July 11, 2016, 03:43:11 PM »
Upgraded to a reusable K & N filter BM-2605. Snagged a great deal on Ebay.
  • 1992 BMW K75S
Offline koapono
« Reply #2186 on: July 11, 2016, 05:20:05 PM »
I mounted new Michelin Pilot Road 4 on the rear of the LT1100 and finally got around to calibrating speedometer using the "soldering iron and resistor adjustment" process outlined in the tech-library. The process is easily accomplished once you set your mind to the task.
My speedo was reading approx 6MPH high according to GPS. I've been meaning to do this for some time but removing and disassembling the instrument cluster is a giant PITA!
Got it dialed in now and works like a champ.
  • 1994 K1100LT
Offline enb54
« Reply #2187 on: July 11, 2016, 10:08:19 PM »
Yah, I did the air pressure check today, just after I got my new windshield! Thanks Parabellum!
  • Red Deer, AB
Eric
Offline The Dude
« Reply #2188 on: July 12, 2016, 02:02:13 AM »
Sometimes,What did you do to your motobrick today,is in my mind.....
I went out to the far shed and had an emotional but cold fondle with My K75S and posed the question:Why do I still like this General Motors metalic Malachite Green?I chose it twenty years ago after the original Candy Apple red had become sun burst orange.
 'Been wondering If I've matured enough to pull off a shark themed paint job on the "machine,yet?
 Open mouth(radiator cowling)rows of white teeth along the side,Red tongue overflowing back.Dark eyeball on top of the tank badge,matt gray with fades into black body all chasing a front mud guardfish...I feel like a new commitment.Start the preparation process....Green or shark?Toin cossing stuff.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline TrueAce
« Reply #2189 on: July 12, 2016, 12:05:58 PM »
Nah, man, take your meds, that bad acid years ago is causing the flashbacks again. :falldown:
  • Florida
« Reply #2190 on: July 12, 2016, 04:20:14 PM »
Buy a K1200rs and you'll already have the look of an orca riding a bicycle.
« Reply #2191 on: July 12, 2016, 05:02:06 PM »
Good choice Laitch and they handle a bit like a whale. :hehehe
Offline The Dude
« Reply #2192 on: July 13, 2016, 12:33:57 AM »
,OK, I've been sussed.Its gone back to Green,again.
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #2193 on: July 13, 2016, 03:21:07 AM »
Go camo and the cops won't see you.
« Reply #2194 on: July 13, 2016, 10:08:39 AM »
Works better on a Ural
Offline bocutter Ed
« Reply #2195 on: July 16, 2016, 07:58:13 AM »
... did get some aniline dye on the bwokx the other day.
... and did the first coat of spar varnish yesterday.
  • Toronto, Canada
« Reply #2196 on: July 16, 2016, 03:00:40 PM »
Geez Ed that is one mighty big top box. What do you carry in it bodies?. You could start a removal service with it, small houses only. Nice job though like the adapted tragkorbs.
Offline bocutter Ed
« Reply #2197 on: July 16, 2016, 06:27:05 PM »
bwokx = wok in a b...x   :lets-eat: There is an ice box under the wok.
  • Toronto, Canada
Offline The Dude
« Reply #2198 on: July 16, 2016, 07:37:41 PM »
Nice!
Do you "pack any heat" with that?
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #2199 on: July 16, 2016, 07:38:40 PM »
I see Ed's mobile catering service. Very innovative next time I have a roadside party I will definitely give you a ring. All I have is an ex army hexi stove.
Regards an enlightened and jealous Martin.
