Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3605730 times)
« Reply #200 on: March 24, 2012, 12:42:58 PM »
Good choice on the Virago.  You CAN learn on a K75 but given their weight and topheaviness they're not the best learner bike around, even if you're tall enough to ride one.
Offline DRxBMW
« Reply #201 on: March 24, 2012, 01:36:24 PM »
Hmm.. maybe I should change out th' coolant too.
Hopefully, wife will be able to pick up these partz (along with new fork seals and "filister head screw" crush washer for upcoming fork tube replacement).
 Maybe an R60 or R75 is in her future someday - those can be altered for short people.
YES, do swap the coolant for piece of mind, EASY, 15 minute worth of K time.
Be aware that the fork drain bolts are VERY prone to stripping. GO SLOW, you have been WARNED !!!
If you resided closer, I know where a complete frame up restoration R 60/5 is up for sale currently. $3800, NICE, I looked at it and took it for a test run. Beautiful but too damn SLOW for my taste.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline conybeare
  • Conybrick
« Reply #202 on: March 24, 2012, 01:55:59 PM »
I recently bought one of these: http://www.jcwhitney.com/aluminum-sealing-120-pc-washer-kit/p2008041.jcwx?filterid=u0j1
Makes the decision of whether to reuse or replace a little bit easier... Handy to have around for the cage, too.
  • Saint Paul MN
Nothing :o
Previous: 2004 R1100S, 2009 Yamaha FZ6,1990 K75S, 1986 K75C, 1984 Honda VT500 Ascot, 1981 Suzuki GS250T
« Reply #203 on: March 24, 2012, 07:24:32 PM »
What did I do to my Brick today, well it was a continuation of an existing project on the '97.
Anyway today I fitted the steering head bearings and started putting the front end back together. Fork tubes, handle bars, wheel, brakes, etc...
Still waiting on the main fairing support bracket to show up.
Also went ahead with a TB sync while I had it up on the table and all the plastic off of it. Damn if that Carbtune isn't easier than the TwinMax for a TB sync.... :2thumbup:
Unless I get ambitious tonight I'll wait with the rest of the oil changes, trans and final drive. Engine oil has already been done.
Then once I get it off of the lift I'll get the brake fluid changed.
« Reply #204 on: March 25, 2012, 10:01:09 AM »
Yessirday I swapped the peg plates on the funkybrick.  Partly becuase I think this style looks better on an RS and partly because I noticed a worrisome crack in the right one where the rider peg mounts.
Old:
"New:"
Crack in the old one:
I also replaced the clutch switch that had a broken spring:
« Reply #205 on: March 25, 2012, 07:32:23 PM »
Finished putting everything back together after my winter projects.  And, got her back on the road!
First a quick trip to a local church parking lot for some figure 8's to get my sea legs back:
Then down the freeway and spent some time going around and around again, this time on a cloverleaf.  Everything seems to be working well!
« Reply #206 on: March 25, 2012, 10:34:29 PM »
I had my brakes inspected today:
Offline TaosBrick
  • RedHotMotoBricker
« Reply #207 on: March 25, 2012, 10:37:16 PM »
Izzat the famous Frankenbrick? Pretty dang Kewl. Cat inspector-dude matches yer paint job.
- Samurai Maxim
« Reply #208 on: March 25, 2012, 11:08:34 PM »
Lookin' good there, Wayne.  :2thumbup:
« Reply #209 on: March 26, 2012, 10:43:26 AM »
Givi E181.  Fits in the same holes as the OEM tail rack.
http://www.twistedthrottle.com/trade/productview/206/
Offline TaosBrick
  • RedHotMotoBricker
« Reply #210 on: March 26, 2012, 09:42:29 PM »
Puttered through my first full fluid change, many thanks to fellow MotoBrickers who offered helpful hints at points where I was stuck!
It'll go quicker next time, now that I know the lay of the land, so to speak. Also installed altitude switch for Jetronic.
Chile Red in the massage parlour.
If I'd been able to get that old planter box positioned right, I coulda drained the tranny and FD at the same time. :hmm:
- Samurai Maxim
Offline motodude
« Reply #211 on: March 26, 2012, 11:40:47 PM »
Thanks for the response.  I never look at the Givi stuff cuz I really don't like the looks of their bags.  Good quality though.
The rack I'm building will mount in the same holes as the factory rack too.  But, it'll have a "hoop" like the large Reynolds rack where I can attach the backrest.
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
« Reply #212 on: March 27, 2012, 12:16:29 AM »
Yeah, the big Givis are a bit gaudy but last fall I installed this 26L on my K1100RS.  Big enough for a FF helmet and looks OK IMO.
« Reply #213 on: March 27, 2012, 12:18:16 AM »
Today I brought the K75F out of winter hibernation and started it up so I could test some rear rotors for warpage.  It was a bit stubborn at first but once it warmed up..... yeehaw.....
Offline TaosBrick
  • RedHotMotoBricker
« Reply #214 on: March 27, 2012, 09:03:02 AM »
GO Frankenbrick!
- Samurai Maxim
Offline motodude
« Reply #215 on: March 27, 2012, 10:11:19 AM »
Their top-cases aren't too bad and shaped to hold a helmet, which is handy.  It is their side-cases that really don't look good (to me anyway).  At least compared to the BMW side-cases.
Tom
'95 K75RT
'90 K75RT
« Reply #216 on: March 27, 2012, 10:28:30 AM »
Tom
Agreed. A lot of their side cases are just big top cases mounted on a side rack.
Offline TaosBrick
  • RedHotMotoBricker
« Reply #217 on: March 27, 2012, 10:33:52 AM »
Hey, What's that tank bag you got there, Duck? I'm in the market for something that is practical, but not too $pendy.
- Samurai Maxim
« Reply #218 on: March 27, 2012, 11:20:27 AM »
OEM.  Made by Multivario and sometimes referred to by that name.
Generally in the $125ish range for a used one with a rain cover in good shape.
« Reply #219 on: March 27, 2012, 03:20:52 PM »
Yeah, right.....and my OEM helmet is made by System IV.
Multivario was just a name BMW put on this type of tankbags....an as usuall BMW keep their cards thight.
At the time when Multivario I was on the market, they had a bag for the boxer with less possibilities
to change to different volume capacities, that was called.........Vario.
Inge K.
« Reply #220 on: March 27, 2012, 04:07:20 PM »
Interesting. I'd always assumed it was the name of the manufacturer.
« Reply #221 on: April 01, 2012, 06:46:29 PM »
Today I finished putting the '97 back together. Put all the plastic back on, took it for a 100 mile shakedown ride.
It all started with fork seals and boots, then steering head bearings, then while I had it all apart the front fairing mount was bent and cracked so it was replaced also.
I also put on the engine bars I got from Drake a year ago or so, as good a time as any.......since I hadn't put them on yet.......
I did a full TB sync including the butterfly plates.
I can't say I've had this bike run soooooo smoooooth.
Brickhead
« Reply #222 on: April 01, 2012, 10:09:00 PM »
Changed the front sneaker. Then had to line up the Motolights again.
Took off the Aeroflow for the summer. Got to get more Velcro dots though.. :2thumbup:
Oh and then took it for a spin :laugh
Offline ccarlsonnh
« Reply #223 on: April 02, 2012, 05:29:10 PM »
Lubed driveshaft splines and changed brake fluid on my K75RT.  New tires went on yesterday.  Coming attractions include changing fork oil and installing headlight relays, additional fuse panel, and LED auxiliary lights.  Spring is coming to NH so I need to get things moving!
1993 K75RT 35K miles blue
New Hampshire
C_Mick
« Reply #224 on: April 03, 2012, 09:56:56 AM »
The K75S had been standing in my garage, minus its front forks, crankcase supported by bricks, for far too long.  I had the fork seals replaced by a BMW garage in Cape Town, but when I was diagnosed with an eye problem, I wasn’t motivated to anything about it.  Now the problem has eased somewhat, I've decided to get it ready for the road.  I have owned it for 26 years and it deserves no less.
The fettling of the bike is going well; I’ve:
Refitted the front forks and re-assembled the front end
Replaced brake fluid for the front discs (the old stuff was the colour of brown ale) and bled the brakes
Checked front and rear brake pads – which were fine
Replaced engine coolant
Changed the engine oil and oil filter
Cleaned and checked the spark plugs
The only nasty surprises so far were to do with the rear brake.   The master cylinder reservoir (made of plastic) had deteriorated and fractured, causing some of the brake fluid to drain off and cause some corrosion elsewhere and on inspecting the master cylinder itself I found some corrosion in the bore, which a friend polished out with Brasso!  (He maintains an old truck in good running order and has repaired many parts which a commercial garage would deem to be non-repairable.)  I hope it works, as a new master cylinder is ridiculously expensive.
So the K75S is being reborn and when the required part arrives from Germany and a new battery is fitted it will soon be ready for the road.  While I'm waiting for the part I will lube the final drive splines and replace the drive and gearbox oils.  (Thanks Dr L Hubbard Duck for my induction in the science of splientology.)
Unexpectedly, I find myself enjoying working on the bike again and it has led to two serendipitous encounters. One was with a German engineer who was responsible for the team of production engineers which developed the BMW System Helmet.  His guys took the design concept from the BMW designers as well as input from many other interested parties e.g. safety specialists and worked all the diverse strands into an engineered product to be handed over to the BMW marketing men.  Unsung heroes no less.  The other was a retired  engineer who lectured at a university in Holland and is a former motorcycle racer. He competed in the 1970s with some of the top riders on the GP racing circuit.  Although I had met him and his wife before, we hadn’t talked bikes previously because neither of us had realised the other was interested.  But when he learned I was working on the bike a connection was made  and later that evening we spent an enjoyable couple of hours chatting over a bottle of wine.  Well they do say motorcyclists are the salt of the earth.
