Author Topic: Front brake caliper O ring?  (Read 3669 times)
jacksdad1963
« on: June 14, 2014, 03:52:30 PM »
I've stripped the front brake on my (spares bike) K1100LT: Finally got the 2 halves of the caliper body apart...not easy!
I now need the rubber O ring that seals the fluid channel, for both calipers, but cannot find a part number. I need a pair of the O ring, or even a repair kit, wouldn't do any harm, as long as its cheap!  :neener:
Re: Front brake caliper O ring?
« Reply #1 on: June 14, 2014, 04:12:38 PM »
Part #23290 at Motobins, £1,50 each.
Offline tg4360
« Reply #2 on: June 15, 2014, 11:04:10 AM »
If it leaks when you put it back together (look for fluid at the seams while you squeeze the lever....) get a piece of plate glass and some fine wet or dry paper.  Wet it and run the mating surfaces over it in a figure eight pattern.
I had one that refused to seal till I did this.  It seems that just bolting them together will distort them enough that they might need this treatment.
Tony G
'79 XS750 "The Triple"
'72 A65T "The T-Bolt"
'68 B25 "The Blue Bike"
jacksdad1963
« Reply #3 on: June 15, 2014, 06:58:53 PM »
I'll try cleaning up the faces as you suggest, and order the o rings as well!
Thanks guys! :2thumbup:
Offline Damun
« Reply #4 on: June 28, 2014, 07:46:49 PM »
If you are in the USA, Yoyodyne carries pistons & seals for all sizes of Brembos.
http://www.yoyodyneti.com/Category.aspx?CategoryID=3017
Offline tg4360
« Reply #5 on: June 30, 2014, 12:37:16 PM »
Man thanks for that link Damun.
Last time I needed o-rings I had to get them from Motobins in the UK.
TG
Tony G
