Author Topic: K75 steering dumper  (Read 3923 times)
Pikejaw
K75 steering dumper
« on: June 08, 2014, 04:36:21 PM »
Hi, Has anyone assembled steering dumper to K75 or K100. If yee, I would be it rested in to hear comments.
Re: K75 steering dumper
« Reply #1 on: June 08, 2014, 08:41:09 PM »
K75's have a steering dampener built into the steering head, the infamous "fluid bloc"  The only ones I've seen on k100s were when they were  used as sidecar tugs.
« Reply #2 on: June 09, 2014, 04:25:23 AM »
K1 and K100RS16V also have a steering damper as standard, but also got a Marzocchi fork and other triple trees.
« Reply #3 on: June 09, 2014, 01:34:43 PM »
Interesting -- I've considered getting a k100 to pull a sidecar instead of a K75 thinking the extra power would be a plus, all other things being more or less equal. But you're saying the 2v K100 has no stock steering damper while the k75 does? That's pretty huge -- I think I'd rather have the steering damper than the extra cylinder for my hack.
« Reply #4 on: June 09, 2014, 03:52:23 PM »
My understanding was the K100 didn't need the dampener, but when they chopped a cylinder off to make the k75 the lighter weight on the front necessitated one.  The K75 dampener is non adjustable, basically a fixed rubber sleeve around the steering stem with a very thick silicon grease providing the friction dampening.  The K100 would make a better tug though you may have to add an external dampener.
