Author Topic: K75 continues to run after shutting down (kill switch or key)  (Read 5801 times)
Offline relayer61
  • 94 naked K75
I'm a non-technical newbie with a 94 K75.  Love the bike but I've had quite a lot of trouble with it since I bought it.  Starter relay replaced; a short from the starter.  I recently had some major work done to the clutch; gears; splines - a real mess.
I've noticed on several recent occasions that when I ride for an extended period of time (1 hour) that the turn signals and horn stop working and that I am unable to shut off the bike.  It wants to keep running whether I use the kill switch or key.   I've checked the fuses.  Not sure what else it might be.
Any help you might offer would be appreciated.     :dunno
Offline subforry
Re: K75 continues to run after shutting down (kill switch or key)
« Reply #1 on: May 19, 2014, 06:51:06 PM »
I don't really know what is in there, but I would suspect some plug, like where the controls plug into the main wiring harness or fuse box.  I would start by removing the fuel tank and having a poke around, better give the wires a gentle pull.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline K75RT Keith
« Reply #2 on: May 19, 2014, 07:12:15 PM »
Are you turning it off by the kill switch  by the starter button or turning off the key?
1990 K75RT
« Reply #3 on: May 19, 2014, 08:38:45 PM »
Does the starter continue to run even after you've started the bike? When you turn the bike OFF is the starter still running, turning the engine over? If so, then you need to fix the starter relay.
You can try whacking the front left corner of the relay box to jolt the starter relay. Otherwise you'll need to disconnect the battery to turn the bike off.
Have your battery load tested. If it's more than 3 or 4 years old, just go buy a new one.
Offline relayer61
  • 94 naked K75
« Reply #4 on: May 20, 2014, 12:35:49 PM »
Keith, I'm using both the kill switch and key; neither one will turn off the bike.
Offline cmattina
« Reply #5 on: June 23, 2014, 06:56:14 PM »
did you ever figure this out? my bike is doing this as well. happened after i adjusted the clutch...
Contact me if you need a hand in the Thunder Bay area.
Offline cmattina
« Reply #6 on: June 23, 2014, 07:07:50 PM »
UPDATE: For me, it ended up being a clutch adjustment issue. go back to the pushrod adjustment screw, it might solve your problem
Offline relayer61
  • 94 naked K75
« Reply #7 on: June 24, 2014, 11:43:12 AM »
Ended up being the starter relay/low battery.  Seems good as new now after replacement of both.  Nice diagnosis TimTyler!!
