Author Topic: Handlebar Risers and Clutch Cables  (Read 6524 times)
1991K100RS
« on: May 14, 2014, 12:12:41 PM »
I've got a question for you guys....maybe someone here has run into this and can save me a headache.
I have a 1991 K100RS that needs a new clutch cable. I also have handlebar risers on the bike.
My question is; If I have handlebar risers, should I be getting longer clutch cable (for K100LT) or stick with K100RS clutch cables?
RS clutch cables part#32732324955 - 1510mm
LT clutch cables part#32732324960 - 1625mm
I could pull the existing clutch cable and measure it, which answers my question, but I find it is a lot easier to replace clutch cables while the old one is still installed (just feeding the new one up through the same path as the old one).
Thoughts?
1991K100RS
Re: Handlebar Risers and Clutch Cables
« Reply #1 on: May 14, 2014, 02:53:33 PM »
Looks like LT bowden cable is needed for RS with risers according to Max's BMW.
I'll post back results... just for fun  :clap:
« Reply #2 on: May 14, 2014, 05:13:31 PM »
depends on the risers and if the c bars are really c bars...
id measure what i had if id were me...
mack75
« Reply #3 on: May 17, 2014, 07:56:39 PM »
Fitted risers from the USA to my K75s here in UK all cables and loom worked fine with no issues, I think you should be okay with standard size but best to measure first I guess.
