Author Topic: Removing front wheel on k1100rs  (Read 3780 times)
Offline roninvt
  • free range, cage free
« on: May 08, 2014, 10:40:29 PM »
Getting new tires for my newly acquired k1100rs.  I had a difficult time getting the front calipers off, some could pull the front wheel.  In fact I had to remove one rotor to make it happen.   Any tricks to this?
1990 K75C
1993 K1100RS
Offline Snowy
Re: Removing front wheel on k1100rs
« Reply #1 on: May 09, 2014, 02:52:34 AM »
You have to remove both front calipers to get the wheel off. They are a very tight fit against the rim so I put some tape on the rim to protect it. As you take the calipers off, press them from side to side to retract the pads which will create a bit more of an angle to get the calipers off the rotors.
  • Marlborough, UK
Offline drut
« Reply #2 on: May 09, 2014, 09:22:58 AM »
Personally I waggle the calipers & then remove brake pads as it makes it easy to get calipers past the wheel.
  • Newcastle upon Tyne UK
Offline roninvt
« Reply #3 on: May 09, 2014, 11:54:46 AM »
Hey there Snowy and drug...Thanks for the suggestions   :bmwsmile
1990 K75C
1993 K1100RS
