Author Topic: Lower temperature Fan Relay Mod  (Read 10140 times)
« on: May 06, 2014, 02:07:12 PM »
The title says it all. I it is very possible to modify the fan relay such that it activates the fan at a much lower temperature, perhaps even an adjustable one.
I will need to look at the other side of the relay board (I think I may have and extra one at home). Basically, the MC3302P is a standard quad comparator. It supplies +12v via a bias resistor for the coolant temperature sensor, and compares the voltage from in between the bias resistor and the CLT sensor, to one in between each of two pairs of resistors that are equivalent to the bias resistor/CLT sensor at 103 °C and 111 °C. These activate the fan and the idiot light, respectively.
I could alter the resistor for the fan switch, to set it to come on sooner, perhaps 95 °C. This would be a trivial modification. I'll do the rest of this once finals are over next week.
Re: Lower temperature Fan Relay Mod
« Reply #1 on: May 06, 2014, 06:09:52 PM »
patiently waiting...
« Reply #2 on: May 07, 2014, 01:17:39 AM »
Seems there are multiple versions of the relay.
The first one uses an "Automotive lamp monitor"
http://www.datasheetarchive.com/dlmain/Datasheets-111/DSAP0024225.pdf
The second one (and the post above) are from later bikes. The pic below of the new type is from a '92.
Offline subforry
« Reply #3 on: May 07, 2014, 11:54:15 AM »
My soldering iron is at the ready and awaiting instructions.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #4 on: August 10, 2014, 10:55:08 PM »
I'm going to get going on this. I might have the parts in hand (I will need a resistor, probably a fairly tight tolerance one).
My fan relay is out of the bike. I have a spare one from a spare harness too, so I will do both of them, If someone wants theirs modified, I can swap for my spare.
Both of mine are the later type. (with the single IC)
First step, I will map out the circuit, and figure out which resistor to modify.
Offline jenkinskg
« Reply #5 on: May 28, 2015, 05:19:26 PM »
Could you just put a resistor in parallel with the temp sensor itself? or series not sure how it is wired
Which is the sensor that controls the fan, same as injection?
« Reply #6 on: May 28, 2015, 11:15:06 PM »
That could work, however, it would also turn the overheat light on early.
Offline jenkinskg
« Reply #7 on: May 29, 2015, 12:26:46 PM »
But then would cool down
« Reply #8 on: May 29, 2015, 03:07:07 PM »
The relay in the first picture isn't the fan relay, but the BMU relay.
« Reply #9 on: May 29, 2015, 03:28:01 PM »
Good catch. Haha
