Author Topic: K100RS 16v rear shock question  (Read 6789 times)
Offline drut
« on: April 26, 2014, 03:40:10 PM »
The rear shock on my 1990 K100RS 16v(30.000ml) is non adjustable and seems adequate at best,a good friend has offered me an adjustable damping shock from a similar mileage 1993 K1100LT for next to nothing.Question is would it offer any improvement:present shock is Bilstein,K1100 shock is Showa.Provided I keep power on & corner smoothly I can manage OK with present shock and it does not leak but ripples/bumps upset the rear of bike whilst front end still feels "planted".
  • Newcastle upon Tyne UK
Re: K100RS 16v rear shock question
« Reply #1 on: April 26, 2014, 09:02:34 PM »
greetings drut...
seeing you are in the uk... i would go with a realm ram and be done with f-ing around...
Offline drut
« Reply #2 on: April 27, 2014, 05:27:16 AM »
greetings drut...
Yep I think you are right I've heard they are good.I'll give them a phone:the link you gave(thanks!)has a 2005 date at bottom & shows a tax rate of 15% when it has been 20% for a while so I hope they are still available
Offline subforry
« Reply #3 on: April 27, 2014, 07:35:30 PM »
The Showa is not rebuildable.  The Bilstein might be.  My guess is that both are dead.  If you want to spend as little as possible, then ask a shop about rebuilding the Bilstein.  Best option is get an after market shock.  There are plenty recommendations here on the forum.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline tg4360
« Reply #4 on: April 28, 2014, 12:45:32 PM »
Also the K1100 shocks may be longer than the 100 shock if your bike is not new enough to have the paralever.
I've put one on my LT as I wanted/needed more ground clearance.
Tony G
'79 XS750 "The Triple"
'72 A65T "The T-Bolt"
'68 B25 "The Blue Bike"
Offline drut
« Reply #5 on: April 28, 2014, 06:54:26 PM »
AFAIK K1100 has same shock length(380mm ?) as K100 16v which as you have pointed out is also paralever,thanks for the input!From what I have gathered up to now:there are no good original shocks & I should look to best aftermarket.
Offline Brad-Man
« Reply #6 on: April 28, 2014, 07:35:30 PM »
IMHO the RAM shock seems to be best for the money and is what I will put on when I get around to going to the paralever rear end I have waiting...
  • Marietta, GA
  • '85 K100
'74 RD350
