Hello all,
Longtime lurker, first time poster here. Hoping you would all be so kind as watch this short video of my 1991 BMW K100rs 16v and help me diagnose this wonky issue I’m having with my starter/ignition switch/starter relay/load shed relay?
When key is turned, headlight intermittently comes on. While starting the bike, the starter kind of ‘chugs’, sounds almost like it is being turned by the engine. If the bike does start, the headlight goes out. I’ll hit the kill-switch and try to start bike again, and it won’t start (hear click, I believe is the starter solenoid opening and closing). You can see this in the youtube video linked below.
I thought maybe it was a dirty starter commutator or burnt out starter brushes. Took the starter out, cleaned it, replaced one of the brushes which was significantly more worn than the other. Reassembled starter. I also purchased a new (aftermarket) battery. Unfortunately, the problem still persists. My next thought is to clean out the ignition switch because I understand that carbon buildup in there can cause these same problems. Unfortunately, the 1991 K100 has the ignition switch housed in the triple-tree, and I need to drill out the ‘security-bolts’ to get in there, or so I'm told (so, I haven’t dug that deep yet)
Please see short video of described symptoms here:
Any thoughts?
