Author Topic: adding denali d2 lights  (Read 3510 times)
Offline roninvt
  • free range, cage free
« on: February 22, 2014, 05:21:19 PM »
Hi...I have a 1990 K75.  Last year I installed an eastern beaver headlight relay kit.  Today I installed a pair of Denali D2s as per the instructions.  These are dual intensity lights, low beam is fine, but no high beam.  I posi-tapped into the white hi-beam wire under the tank.  Are the eastern beaver and denali relays messing with each other?   I am thinking about tapping into my hi-beam wire between the headlight and the beaver relay.  Any thoughts...
1990 K75C
1993 K1100RS
Re: adding denali d2 lights
« Reply #1 on: February 22, 2014, 07:10:21 PM »
If you tapped the same hi-beam wire for both relay setups I'd suspect a problem with your Denali relay.
Did you remove the EB relay's? If not, do they still work right?
Offline roninvt
« Reply #2 on: February 22, 2014, 07:19:13 PM »
Hi Scott,   The EB is working fine, I have hi and low beam on headlight.  Only low beam on Denali.  It does sound like their relay may be faulty.  Thanks
1990 K75C
1993 K1100RS
