hi,
sorry 'bout the title but it pertains to the battery and the rubber grommets/nuts that hold the tray in place. I recently had my second gear go out on me so I replaced my tranny and saw that the two rear rubber bolts were not sscrewed in because the thread on the tranny was worn out, so I thought, yes, with my new secondhand tranny that problem is fixed, however when installing my secondhand tranny, i noticed that the threads were also worn out.
How could I proceed and what do you guys think?
1. Tap a new thread that is bigger into the tranny, bu then the rubber nuts will not be able to screw into the new thread(because it is obviously bigger than the original thread)
2. just hold the battery in place with 2 of the 4 nuts(dangerous when braking as the momentum will lift the battery) but do not care
3. Lengthen the grommets/nuts by welding a piece of nut on the end of the nut, and securing it with a bolt(but will the bolt not hit the hasuing for the drive shaft)
4. weld the grommets to the tranny( but how do i remover the battery tray later when i cannot turn the grommets anymore)
5. Another idea?
Hope anybody has an idea or a best idea out of the choices above?
(i am guessing that is a fairly common problem as the two tranny's i have owned and own both have this problem, but i do not seem to be able to find an answer)
