Author Topic: Bmw k75 clutch cable question and fix (machined npple to hold end if snap)  (Read 4134 times)
Offline Oliver
okay two questions...
Clutch cable just snapped it was a cable for the S bars. I was wondering if anyone has ever tried using clutch cables from different  BMW models. I have used a high handlebar f850 cable before but I was wondering if anyone has tried or knows of any other models with clutch cables that will do the job?
the k bike cables seem to be the most expensive.
Also is it worth it to get featherlight cables rather than OEM?
Re: Bmw k75 clutch cable interchange question and featherlight question also
« Reply #1 on: February 12, 2014, 10:15:45 PM »
i have replace 2 motobrick clutch cables... i went oem because they are robust and the proper length and have the correct ends...
Offline Oliver
« Reply #2 on: February 19, 2014, 09:45:07 AM »
We machined a nippple with a set screw that pinches the cable and I also bought a new OEM cable. So now if anything does snap I can just put that end on rather than carrying a spare cable
« Reply #3 on: February 19, 2014, 10:12:41 AM »
yawl on the nipple... heres a store boughten one...
http://www.motobrick.com/index.php?topic=1033.0
have fixt others motos so they could getts home... clutch cables and throttle cables...
never leave home without thems...
j p
Offline K75RT Keith
Re: Bmw k75 clutch cable question and fix (machined npple to hold end if snap)
« Reply #4 on: February 19, 2014, 10:51:50 AM »
Pretty slick.  Gotta find a set and some aircraft cable for myself
1990 K75RT
« Reply #5 on: February 19, 2014, 11:19:58 AM »
both of those nipple deals can be found in the hillman brand fastner trays at most local ace hardware stores... the cable too...
lawn mower places have them too cause they are choke and throttle cable ends used  on older small engines...
