Author Topic: K75S crankcase breather hose  (Read 4499 times)
Offline Liverpool Brick
  • Another Brick in the hall.
  • Fr. Jack Hackett: "I love my brick!"
« on: January 27, 2014, 10:28:25 AM »
Hi,
Carried out routine filters, plugs and oil service on my '91 K75S and whilst the filter box was apart I checked the crankcase breather hose which turned out to be split. Fitted a new one and yeeeeehaaaa! Its a new bike! So, my advice is check that hose and fit a new one if needs be. Its an easy, cheap repair and the benefit is that much joy abounds.
Keep 'er lit,
Andy
  • Bangor, County Down, Norn Iron
Sure nuff 'n yes I do.
1991 K75S
2011 R 1200 RT SE
Offline vrmntynkee
Re: K75S crankcase breather hose
« Reply #1 on: February 17, 2014, 02:26:17 PM »
Hi Liverpool, I just picked up a neglected K75. it was left out in the weather, i would say most of it's life. Its a '94. Anyway my question is did you se an improvement in engine operation after fitting new breather? This bike starts easily but is finicky on idle. Acceleration produces skipping and backfiring. I replaced the breather and vacuum nipples (they were cracked as well). I think there is a slight improvement in the running, bit still far from right.
Just looking to see if an air leak might be the problem...
Thanks!
Offline Fossil
  • '91 K100rs4V caretaker
« Reply #2 on: February 18, 2014, 07:31:45 PM »
Start the bike and use an unlit propane torch around the throttle bodies and rubber mounts and watch for increased idle rpm. Increase in idle speed indicates a need for new throttle body rubber mounts(?) These bikes are very finicky over tiny vacuum leaks.
How can you be lost if you don't give a crap where you are?
« Reply #3 on: February 19, 2014, 04:11:00 PM »
+1 on throttle bodies hoses. I had to rebuild mine because of micro cracks probably due to weather exposure and some overheating I had because of a bad fan. Runs great now. Btw I didn't know that about the propane torch...I had to wait till the leak was bad enough to hear with a straw in my ear.
I'm sure there's a long thread on the throttle bodies rebuild in here somewhere...there's an issue with the clamps. I think you can only use oetikers on some of them because of space issues. I had to get a tool to do the job.
