Author Topic: Trans oil - K1100RS  (Read 7204 times)
Offline subforry
Trans oil - K1100RS
« on: December 09, 2013, 01:54:38 PM »
Hi all,
On Friday I changed the trans oil on my K1100RS.  The oil that came out looked, felt, and smelled like ATF.  Was this correct?  I used Mobil 1 75w-140 synthetic gear oil.
Thanks.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline Grim
Re: Trans oil - K1100RS
« Reply #1 on: December 09, 2013, 05:15:28 PM »
Manual say 80w90 on a conventional oil. The Mobile 1 you put in should be just fine. Thats what I plan to use my next change.
I wonder if some general repair place did the last change on your bike and just didnt use what it calls for?
 Some manual transmissions do use ATF but not typically recommended for BMW bikes that I am aware of. Ive known people to use ATF in cold climates with sub 0 temps in place of gear oils but I think what you put in is the better option.
1995 Morea Green K1100LT
Offline K75RT Keith
« Reply #2 on: December 09, 2013, 05:21:27 PM »
Mobil1 is fine.  If you're really concerned, order some Guard Dog Moly for transmissions with synthetic lube and add it to the trans and the final drive.  I'm guessing you also changed the final drive oil too.
Unless you felt or saw shavings or bits of metal (more than a few) in the gear lube or on the magnetic drain plug, you're good.
1990 K75RT
Offline subforry
« Reply #3 on: December 10, 2013, 12:37:43 PM »
Thanks guys.  The shifts feel better with the new oil.
I have not changed the final drive because I was waiting to pull it and lube the drive shaft splines.  My bike has 22k miles.
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #4 on: December 10, 2013, 03:14:13 PM »
you mean like this...
104 thousand total miles on this fd... amsoil till 50k... mobile 1 since... new every approx 20 thousand... 18 thousand on the last final drive oil change b4 bearing failure...
Offline MEL
  • 95 K1100LT
« Reply #5 on: December 10, 2013, 10:49:17 PM »
OUCH that must have hurt....at least the wallet...
Imagine that.
1995 k1100LT
