Author Topic: Fuel tank and crankcase breather hose  (Read 5488 times)
Offline subforry
« on: November 17, 2013, 08:53:12 PM »
Hi all,
When I removed my fuel tank (1996 K1100RS), there is a small hose that seems to be a breather hose.  It has a check valve.  It was connected to nothing (other than the fuel tank).  There was also a small hose connected to the top front of the crankcase.
Seems like these should be connected, so I did this and after a short ride a film of oil started coming form the left has side of gas tank cap.
So where should these hose be connected?
Thanks.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Re: Fuel tank and crankcase breather hose
« Reply #1 on: November 17, 2013, 09:13:26 PM »
can you post a photo of it or post the fische with item number...
Offline Grim
« Reply #2 on: November 17, 2013, 09:28:26 PM »
The front hole goes to the line with the check valve is for the automatic oil thinning device care of the Commie Airsucking Revolting Bastards  organization AKA CARB. Its suppose to recover vapors from the gas tank and send them through crank case vent to be burned. In reality if you over fill the tank and it burps raw fuel it dumps that raw fuel into your crank case. Most of use do the Air Recovery cup mod.
http://www.motobrick.com/index.php/topic,989.msg3961.html#msg3961
The rear hole is the drain around the gas cap if water gets around it when raining or washing it. Sounds like you got them reversed or if I read that right the hose to the crank case became disconnected from that check valve and you stuck it to the drain. The drain hose can drop down out of sight but should be there if you look.
1995 Morea Green K1100LT
Offline subforry
« Reply #3 on: November 18, 2013, 02:53:47 PM »
Thanks Grim, just the info I needed.
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
