Author Topic: Runnig light in mirror upgrade with pics  (Read 3611 times)
Offline subforry
« on: November 17, 2013, 08:08:29 PM »
I added some dual filament bulbs (1157) to the mirror turn signals on my K1100RS.  I removed the connectors, used a Dremel to bore out the plastic holder to allow for a dual filament base.  The fit was tight enough but I used some thin CA glue.  Then ran wire from the headlight running light to the mirrors.  Uses standard 1157 bulbs.  Here are some pics.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Re: Runnig light in mirror upgrade with pics
« Reply #1 on: November 17, 2013, 08:25:59 PM »
righteous...
« Reply #2 on: November 17, 2013, 10:16:37 PM »
As you are running those, keep an eye on your plastic lenses for heat discolouration or deformation.
The heat generated from a running light in a space that wasn't designed for a incandescent running light may cause you problems.
I'm not saying that it absolutely will, but just beware that it's a possibility.
You may consider a dual wattage LED lamp, same dual purpose but no heat....
Offline subforry
« Reply #3 on: November 18, 2013, 02:46:38 PM »
Scott_ Thanks for the tip.  Will 1157 led bulbs work with the stock turn signal relay?
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
