Author Topic: ABS rear brake issues  (Read 3445 times)
Offline hartrepair
  • Reich-rocket rider
« on: November 10, 2013, 03:44:58 PM »
Working on my K1100RS (1995) 67000miles. Replaced rear disk with a used but good part. The old one was badly worn and looked as though it might have been over heated. I had flushed the ABS 2yrs prior untill the fluid was clear. I installed new pads this time around. I noticed as I blead the system again that the brake pedal felt odd...like it was binding,the rear brake wouldnt release quickly either. I blead it some more and the fluid was clear once again, a few tiny particals floating around in it. After ride to work and back I felt the rear brake drag a bit, again. I took the master cylinder apart and carfully cleaned it. I flound nothing unusual ,all the ports were clear. I blead it through the ABS module,clear fluid. Blead the caliper, the fluid was a bit darker. I could stomp on pedal, the wheel would spin freely. Crazy stuff... pulled the flex brake line and found all kinds of rubber chunks clogging the caliper port! Order new Galfer SS lines front and rear.
'70 Mobylette
'61 Lambretta
'76 Suzuki GT550
'51 BMW R51/3
'71 Moto Guzzi Ambassador
'74-'75 Suzuki RE5...4 of them at once!
'95 K1100RS
Offline hartrepair
Re: ABS rear brake issues
« Reply #1 on: November 16, 2013, 04:41:14 PM »
I took the rear brake caliper apart and discovered an abundance of rubber chunks inside. There is no doubt these chunks can clog up the passages and act like "check valves." This will become a problem as our machines get older. The brake lines seem to be the source of these rubber chunks.
'70 Mobylette
'61 Lambretta
'76 Suzuki GT550
'51 BMW R51/3
'95 K1100RS
Offline roninvt
  • free range, cage free
« Reply #2 on: November 16, 2013, 06:08:33 PM »
I think the inside of the brake lines fail way before the outside shows cracks, etc.  great reason to put s/s brake lines on yer to do list.
1990 K75C
1993 K1100RS
