Author Topic: Power loss and reprograming  (Read 5465 times)
Offline pfy50
  • Boat or Bike:Get Going, Get Out & Get Lost
« on: November 05, 2013, 02:48:37 AM »
A question on battery removal. I have 1994 K1100RS and I thought I saw a note in the manual that if the battery is disconnected (Like for winterization or replacement) you will have to go to a dealer and get the bike's ECU or throttle sensor reprogrammed.  :eek:
Is this true for this model?? If so what do you do every winter if you don't have the option of leaving it on a charger(no power @ storage facility)?
:mbird
'94 K1100RS
'08 KTM 990 ADV.
'11 YAM. WR250R
Re: Power loss and reprograming
« Reply #1 on: November 05, 2013, 06:48:00 AM »
It's bull........The only thing that would need re-programming would be a radio unlock code on an LT or RT.
You will be just fine with an RS.
Offline programmasters
« Reply #2 on: November 05, 2013, 07:33:15 AM »
True, a kbike is a 'dumb' bike. The ecu is hard coded into a chip, so loss of power is no problem at all
Offline Grim
« Reply #3 on: November 05, 2013, 06:02:20 PM »
Worst thing that may happen is you trip the ABS light. Search ABSII reset. It's easy to do. Just need a little wire and to find the diagnostic plug and ground a pin out for 30seconds while holding the ABS button.
Fact is now that I have told you that you may know more about resetting it then your local dealer. My local dealer didn't know and doesn't have a computer that works with k1100 or older
1995 Morea Green K1100LT
« Reply #4 on: November 05, 2013, 08:40:00 PM »
solar battery tender hanging off the roll up door plugged into your powerlet...
Offline pfy50
« Reply #5 on: November 06, 2013, 01:19:08 PM »
Thanks Guys :clap:
I only have the Clymer Manual and it makes you think, "Where they come up with some of the things they put in the manual," and my other beef with them(Generic Manuals) they often just skip steps assuming the guy who is working on it is a mechanic or something and has done this job before and just needs a refresher :dunno :musicboohoo:
johnny: as for the solar charger; it won't work as I have put the bike away until money and time allow to continue working on this little brain teaser (K1100RS). It is in one of those commercial storage units(inside) which unfortunately doesn't have any available sun light or power outlets.
'94 K1100RS
'08 KTM 990 ADV.
'11 YAM. WR250R
« Reply #6 on: November 06, 2013, 01:26:58 PM »
you could store it at pallums place... butts it may be missing parts next time you see it...
Offline pfy50
« Reply #7 on: November 07, 2013, 11:49:08 PM »
That would:cowpoop: :laughing-on-ground:
'94 K1100RS
'08 KTM 990 ADV.
'11 YAM. WR250R
