Author Topic: Alarm wiring  (Read 5883 times)
Offline eddy1a
Alarm wiring
« on: October 12, 2013, 06:56:38 AM »
Hi people, I am in the process of getting ready to install a bike alarm on my 1992 K1100LT. I've come up against a minor issue which hopefully someone out there will know without my having to dig through wiring looms. I need to find a switchable live which is on when the ignition is on and off when the ignition is also off. Any help with this would be very much appreciated, Thanks in advance  :bmwsmile
Re: Alarm wiring
« Reply #1 on: October 12, 2013, 09:09:40 AM »
In the relay box you find a round white connector which is for the factory alarm, the green/brown
wire is switched power.
Or if you don't have factory heated handles.........this connector you find at left rear under the fuel
tank. It's a two pole connector ... green/black and brown wires ... the green/black is switched power.
Offline eddy1a
Re: Alarm wiring
« Reply #2 on: October 12, 2013, 10:17:24 AM »
Hi there Inge.K. thank you so much for the swift reply, I shall take a look at the connector. Would I be right in thinking that some of the other wires on this connector are positives for the indicators ?
Re: Alarm wiring
« Reply #3 on: October 12, 2013, 10:47:31 AM »
It isn't any connectors for the indicators..........it's a four pole connector:
Unswitched power, switched power, ground and and output to the horns.
Offline eddy1a
Re: Alarm wiring
« Reply #4 on: October 12, 2013, 10:50:25 AM »
Okay, thanks for looking in to this for me, I shall use the positive feeds to the rear indicators. Thanks once again  :2thumbup:
Re: Alarm wiring
« Reply #5 on: October 13, 2013, 06:52:00 AM »
As a additional info it can be mentioned that the switched power at the green/brown wire is connected via fuse #7.
Re: Alarm wiring
« Reply #6 on: October 13, 2013, 09:33:53 AM »
And the un-switched power on the red/green wire is from fuse #4
The green/grey is for the horns and brown is ground.
