Author Topic: 95 K11, rebuilt R-Master cyln will not bleed fluid.  (Read 3167 times)
mawker
« on: October 06, 2013, 11:27:09 AM »
rebuilt the rear MC new w/new parts. Cleaned and soaked the cylinder before assembly, used compressed air to blow all MC passages clear, checked all lines from MC to calliper for blockages, none found. I tried to prime the MC by pumping a few times; nothing. Pulled a vacuum directly on the MC; no flow.
What gives ??
Any idea of a mistake made ??
Offline hartrepair
  • Reich-rocket rider
Re: 95 K11, rebuilt R-Master cyln will not bleed fluid.
« Reply #1 on: October 06, 2013, 07:46:03 PM »
ABS? I used a Mightyvac to pull fluid through my ABS equipped K bike
'70 Mobylette
'61 Lambretta
'76 Suzuki GT550
'51 BMW R51/3
'71 Moto Guzzi Ambassador
'74-'75 Suzuki RE5...4 of them at once!
'95 K1100RS
zonenfeile
« Reply #2 on: October 08, 2013, 03:37:27 AM »
usually filling the rear brake makes no probs even with ABS
check the clearance MC-> Pedal - that´s important
`cause I did not want to waste endles hours for pumping anymore:
Might be helpfull
We´ve got some advises in the Wiki for using that system
just put it into google translator
34 - Brake system venting
