i don't have the trans oil dipstick. I found this here …...
Take a piece of coat hanger wire, put a right angle in one end of it and then put a small bend in it 115 mm (a tad over 4.5") away from the right angle
i'm a little (ok, a lot ) dense, but this doesn't make sense to me. I assume the right angle is a handle of sorts? the 4.5 away slight bend is what? helps fit it in past the gears? how much is a slight bend? How long is the wire after the slight bend? How is it read?
Told you I'm dense! :2thumbup:
