Author Topic: Next, the fuel fill neck.  (Read 10922 times)
Offline Shoganai
« on: May 26, 2011, 02:16:21 PM »
See that screw...I didn't at the time of this photo.
It was worse than I expected.
Bad gasket, will replace.
I cleaned off all the loose stuff.
All cleaned up.
I had to come up with a way to clean this up w/o trashing the fuel filter.
So I did this and used a SS wire brush and a vacuum to remove most of the debris.
The wire brush couldn't get it all, so I had to use fine sand paper, and again with the vacuum.
All done until the gasket set gets here.
Now I picked up that spring, not sure where it came from, but while cleaning up I found another spring.
As I figured out, the second spring wasn't part of this project.
I wonder if there is anything I could seal the pitted set with that wouldn't breakdown in the presence of fuel?
Re: Next, the fuel fill neck.
« Reply #1 on: May 26, 2011, 02:24:25 PM »
Gasket sealants are usually resistant to petroleum products - read the label and it will tell you.
Offline Shoganai
« Reply #2 on: May 26, 2011, 02:27:52 PM »
Do you think I should put something like gasket sealant on there?
« Reply #3 on: May 26, 2011, 02:32:07 PM »
Sure, why not?  I can't see it doing any harm.
Offline Shoganai
« Reply #4 on: May 26, 2011, 02:37:20 PM »
Thanks, I'll do it.
