Author Topic: Fuel injection adjustment screw o ring size  (Read 3761 times)
lhead
« on: August 20, 2013, 12:28:19 PM »
My 1993 k1100rs is apart and I'm working on refurbishing the FI system. The majority of the rubber hoses and associated bits are original - i.e. 20 years old. My concern today is the O rings that fit around the air adjustment needle valves. None of the rings in my Harbor Freight set will work. I don't know exactly what the size of the OEM ring is.
Has anyone else here replaced these rings? And idea of size or source?
Thanks Guys
Charlie
Offline Grim
Re: Fuel injection adjustment screw o ring size
« Reply #1 on: August 20, 2013, 05:31:33 PM »
Hmmmm normally its easy to look up parts but if you and I are on the same page I'm stumped.
Lot of parts like bolts when you drill down to them in the online catalog it will reference the size. I just cant seem to find the catalog showing those O rings as a separate part.
I think your talking about "adjusting screw" Part # 20 on this diagram.
http://www.bmwmcchattanooga.com/showAssembly.aspx?ukey_assembly=194649&ukey_make=398&ukey_model=7529&modelYear=1993&ukey_category=8483&ukey_driveLine=121&ukey_trimLevel=743
1995 Morea Green K1100LT
lhead
« Reply #2 on: August 20, 2013, 08:20:22 PM »
#20 is exactly the part. No separate O ring mentioned.
I'm thinking about doing a measurment on the ring size and looking it up on McMaster Carr. Then I'll have 96 extras.
lhead
« Reply #3 on: August 22, 2013, 03:51:14 PM »
So I measured the o ring size for the FI brass screws. 5.5mm ID, 1.0mm cross section. Ordered a pack of 25 from McMaster Carr today.
