Author Topic: K75 Necessary Base Amps  (Read 3960 times)
« on: August 04, 2013, 08:23:47 PM »
How many amps does a bare bones K75 require from the alternator to run without draining the battery?
I'm trying to calculate how close I am to reaching the 32 amp limit my alternator can provide using know values from the lighting and accessories I have on my bike.
Fortunately my accessory lighting is LED (4 amp total) but I've also got a couple of USB draws and occasionally a 5 amp heated vest.
Offline motodude
Re: K75 Necessary Base Amps
« Reply #1 on: August 05, 2013, 12:49:02 AM »
Hi Tim,
I don't have any hard numbers or anything.  But on my '90 K75, with the same 35w alternator, I could run both my vest and (factory) electric grips simultaneously for hours without any noticeable problems with the battery.
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Offline Grim
« Reply #2 on: August 05, 2013, 09:38:34 AM »
The bulbs would be easy to do the math on. It's the pump and engine management components you need to figure out.
Got a VOM? Many can handle a 10amp draw on the current settings. On my bike the power going to the fues box is on a separate lead then the power for the starter so you shouldn't have a problem hooking it up. I'd say 10amp would be plenty to run the bike and lights.
1995 Morea Green K1100LT
« Reply #3 on: August 06, 2013, 10:31:00 AM »
Thanks. It sounds like I probably don't have anything to worry about.
Thorfinn
« Reply #4 on: August 07, 2013, 07:13:35 PM »
..Certainly nothing on a USB cable is liable to cause you any concern. Very little current draw is even possible on that protocol. In general, K-bikes have simply oodles of electrical capacity compared to Airheads. Worry not, old bean. :euro
