Author Topic: torque on rubber TB connector bolts  (Read 2933 times)
Offline Lawrence
« on: August 03, 2013, 12:24:55 AM »
This weekend I aim to fix (yet again!) a vacuum leak in the rubber connectors that attach the TBs to the head on my 1985 K100RS.  Some say install the connectors dry/ others suggest something like Permatex blue (?).  Well, if I go with a gasket maker material, I'll be sure to use a high temp/ gasoline resistant one. The bolts that fix the rubber connector to the head are to be torqued to 4 ft/lbs.?  That seems very light. Your ideas/opinions please.
TIA
1985 K100RS
1982 Laverda Mirage 1200TS
1983 BMW R100RS
Re: torque on rubber TB connector bolts
« Reply #1 on: August 03, 2013, 01:42:26 AM »
Any gasket stuff should be flexible. Blue would work. I used the 3-bond stuff.
Torque is 9nm, standard for basically all of the bolts that size. Just get them snug with an allen wrench, as most torque wrenches don't reliably go that low.
Offline Lawrence
« Reply #2 on: August 03, 2013, 12:20:06 PM »
Thank you, sir!
1985 K100RS
1983 BMW R100RS
