Author Topic: brake bleeding...  (Read 3768 times)
Offline branandfox
  • Loraine. K1050RS
brake bleeding...
« on: July 25, 2013, 12:03:39 PM »
SO! upon reinstalling all of the rear end (see my post in projects) and cleaning the leaves situation, I installed new rear brakes and a EBC rotor. the problem is that I had to disassemble the rear brake and clean it really well to get it moving freely again. So now the little "speed bleeders" I bought won't bleed the system. what do you guys use to bleed brakes? are the vacuum containers worth the price and work well? any tips on this job would be welcome. first teardown of the bike. Kind of learning as I go!'
Hit the throttle and live.
Don't blink.
Don't slow.
Just breathe.
Offline Grim
Re: brake bleeding...
« Reply #1 on: July 25, 2013, 06:23:27 PM »
I've done both vac and pump method and had no problems with either. Do you have ABS?  I know on my 95 I have to bleed the servo first (till I scraped it;) )
1995 Morea Green K1100LT
Offline 552255
« Reply #2 on: July 25, 2013, 10:34:02 PM »
harbor freight vac. pump bleeder...worth it definitely.  Keeps mess off floor, and works to pull old fluid out.
'97 K1100LT-SE
'96 k1100RS-SE
Offline branandfox
  • Loraine. K1050RS
« Reply #3 on: July 25, 2013, 10:52:13 PM »
I got a mittyvac from autozone. Ill be using it shortly. Hopefully itll do the trick.
Don't blink.
Don't slow.
Just breathe.
