Author Topic: 1997 K1100lt ABS II  (Read 4009 times)
Offline jav37
1997 K1100lt ABS II
« on: July 09, 2013, 06:40:29 PM »
Has anyone had any luck repairing the ABS module? Any week internal parts more likely to fail over any others? Any way to test the unit out of the bike? I have a #7 code that points to the ABS module any other causes of the #7 code?
Thanks for any help
Re: 1997 K1100lt ABS II
« Reply #1 on: July 09, 2013, 07:59:44 PM »
greetings jav37...
abs fault codes are known to be reliable... time to look for a parts bike...
Offline Grim
« Reply #2 on: July 09, 2013, 09:55:59 PM »
Pull the plug off the brain and inspect it for any damage that looks like it was shorted out. If somebody forgets to put the ground back on the block and tries to start the bike it will pull ground through the ABS and fry it.
1995 Morea Green K1100LT
« Reply #3 on: July 09, 2013, 10:22:56 PM »
Thanks for any help
Read this link.
http://bmwk10075abs1fix.web.fc2.com/
Sounds promising, at the bottom of the page are details about a change to reading the fault code if you are getting fault #7.
