Author Topic: Speedo internal lighting, bulb suppliers?  (Read 4077 times)
Offline KCinSB
« on: July 05, 2013, 11:12:21 PM »
For a '93 K1100RS, I have several bulbs out in the gauge pod, and the clock is the one I miss the most. Anyhow, last time I went through this drill some years back, it was a hassle getting the BMW shop to order the bulbs,........ no profit margin I'm sure. Anyhow, does anyone have info on replacement bulbs? I like the stock green shade. Also don't want them too bright. OEM bulbs would be perfect.
  • Santa Barbara, CA
  • SOLD
Re: Speedo internal lighting, bulb suppliers?
« Reply #1 on: July 05, 2013, 11:34:51 PM »
If you are going to open the speedo pod up again, why not just replace the lamps with LED's and be done for a long time.
Check with Duck at kbikeparts.com
If not maybe he will sell you some of the old lamps he's removed.....
bikerboy
« Reply #2 on: July 06, 2013, 04:07:22 PM »
Thousands of LED versions on ebay, I have sets of red, green and blue ones that cost peanuts.
« Reply #3 on: July 06, 2013, 10:35:34 PM »
Duck's LED instrument light kit is worth every penny. He put a lot of work into figuring out the right bulb for each application. AND, he marks each bulb's polarity, which is essential.
Bill
WhiteTassieDevil
« Reply #4 on: July 09, 2013, 09:18:55 AM »
 :clap:
Hi
FrakenDucks LED bulbs are worth going for. I replaced the main bulbs on my K1100LT, with his LED's. Everything worked according to the instructions provided, I removed the screen and inner cover to get to the dash connector easier then followed the supplied instructions to replace the bulbs.
Brian
