Author Topic: Fork Oil Question  (Read 6354 times)
Offline argent brick
Fork Oil Question
« on: June 27, 2013, 02:17:45 AM »
Now that my fork seal is not leaking I want to flush the front forks and put in new fork oil. I am considering 10W even though my bike came from the factory with lighter oil. BMW wants almost 40 bucks for the stuff. On top of that, I get have over a two hour drive and bridge toll to buy from a dealer.
Anyone have suggestions for something good that I can pick up locally and save the commute cost (I won't be taking my bike) and maybe a couple of bucks on the oil?
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Re: Fork Oil Question
« Reply #1 on: June 27, 2013, 02:36:24 AM »
The 10W stuff is fine. Better even.
« Reply #2 on: June 27, 2013, 06:37:47 AM »
I buy BelRay high performance 10W fork oil from another bike dealer because they are close. Unless you are in a major hurry, you could have some shipped in to save you commuting cost, or if your work commute takes you close to another bike shop that's another option.
I had considered a different type of oil, but have stayed with oil that is at least intended for motorcycle forks.
Offline sh00ter
Fork Oil Question
« Reply #3 on: June 27, 2013, 07:22:27 AM »
Motul has been great for me. Use 10w
'94 1100 RS
« Reply #4 on: June 27, 2013, 04:59:30 PM »
Cool. I can get BelRay or Motul without any problems. I have the Showa forks. Anyone know how much oil I need per side?
Lynn
1976 R60/6 RIP
Offline sh00ter
Fork Oil Question
« Reply #5 on: June 27, 2013, 06:41:37 PM »
Not sure your bike but I believe it's 400ml r and 350ml L for a fill.  400ml both if you have disassembled them completely.
'94 1100 RS
« Reply #6 on: June 29, 2013, 11:15:34 AM »
greetings argent brick...
look here for quantities...
what i do is use is honda ss-8-10 fork oil... fill a measuring bucket with the proper quantity... suck it out of the measuring bucket with a meat injector n fill er up...
note... the meat injector has a slack jaw needle... i cut the end off straight so the juice goes straight in hole instead of squirting out the side...
Offline K75RT Keith
« Reply #7 on: July 04, 2013, 12:05:16 AM »
Just drained BleRay 15w out of my forks and added much lighter weight oil 7,5 wt.  Depending on the brand and actual viscosity (since no standard exists) 10 weight may work fine.  Or, it will feel like you have solid suspension
1990 K75RT
