Author Topic: Best Switched Wire to Tap for a Relay?  (Read 4942 times)
Offline AR-Trvlr
  • Bushpusher
« on: June 25, 2013, 07:23:48 AM »
I'm going to add a circuit to power a powerlet on my dash and power a GPS.  I'd like them to be switched if possible - what's a good wire to tap to switch a relay?  Any suggestions?
Current Bike: '87 K75C  Former Bikes: '92 Nighthawk 750, '94 Barbie KLR 650, '03 Bandit 1200S
Offline wmax351
Re: Best Switched Wire to Tap for a Relay?
« Reply #1 on: June 25, 2013, 02:35:44 PM »
Take a look at the wiring diagrams in the library. I use one of the ones on the "auxiliary equipment connector"
  • Albuquerque, NM
Bikes:
« Reply #2 on: June 25, 2013, 02:57:24 PM »
+1
I used the "Anti-theft" connector. Of the hot leads on that is switched, and one is not.
Offline jay1622
« Reply #3 on: January 22, 2017, 04:37:40 PM »
+1
Found this thread while trying to determine where to hard-wire my GPS mount. I'm going to install an AMPS mount through the K75S handlebar bumper; particularly through one of the auxiliary switch cut-out's. Everything should work. And yes, if this applies to any of you out there, the BMW Navi V will work with this Garmin "specific" mount. More to follow!
https://www.amazon.com/gp/product/B01CUM2UFS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B001PO6JD2/ref=oh_aui_detailpage_o02_s02?ie=UTF8&psc=1
  • Charlotte
  • Previous: 1986 K75S, 1977 R75/7, 1999 R1200C, 2003 R1150GS, 2001 F650GS, 2005 R1200RT... Current: 2005 R1200RT and my Brick, a 1988 K75S
Offline RobP
« Reply #4 on: January 22, 2017, 07:45:20 PM »
I used the green/black wire in the  'extra equipment' plug for my add-on LED driving lights.
  • Driftwood, TX
  • 1985 K100RS
